Old 10-27-2014, 02:22 PM   #1
Default TC6.1 steering servo
I can use my BLS451, already installed in my B44.2, or use a JR z8800s.
Which one would be better? Will I see a difference? Using a Futaba 4PX
Thank you!
Maxime is offline   Reply With Quote
Old 10-27-2014, 03:14 PM   #2
Trader Rating: 23 (100%+)
Generally i'd prefer same brand radio equipment + servo (eg. futaba+futaba, sanwa+sanwa,etc) due to matching of software between the equipment; in the same way same brand speedy+motor might respond quicker.
Not sure if it leads to any actual results, but it might make you feel better haha
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-27-2014, 03:54 PM   #3
I'd go the JR
It's a little faster and has more than enough torque for TC. Nothing in the weight between the two. It will possibly use a little more power not being brushless, but will be minimal.
If you are buying new though, I'd be looking for something low profile.
What ESC are you running - BEC specs?
cplus is offline   Reply With Quote
Old 10-28-2014, 01:37 PM   #4
Thank you. I ended up installing the Futaba... I can use "digital" mode now, maybe this will compensate for the slightly slower speed than the JR servo.
I'm using a Tekin RS Gen 2 ESC
