Old 10-24-2014, 10:58 AM   #16
It just came up through the dust seals.
I am going to try it again with a thicker grease when I get back to my shop.
Hopefully that will work.
user1 is offline   Reply With Quote
Old 10-24-2014, 11:42 AM   #17
Smile
Sorry buddy, but I had the same issue with one of my Novak bearings, and I had to cook the backplate until it went from black to bronze before the bearing got loose....After that, the bearing was garbage, but I installed a new ceramic bearing easily... Maybe the acetone could not get to all the glue, but the heat sure will... I would cook it until I smell the CA glue burning, then pull the bearing out while hot...
Originally Posted by user1 View Post
Well so far the acetone to loosen the glue hasn't worked and the grease to hydraulically lift the bearing out didn't work. This timing plate is kicking my arse. I called Novak to get a new one and their customer service is closed on Friday. I guess no one needs help on Fridays.
bertrandsv87 is offline   Reply With Quote
Old 10-24-2014, 11:48 PM   #18
niznai's Avatar
Okay, that's a good sign. You're on the right track.
Thicker grease is a good idea. I would suggest as well to hit the drift/pin with the hammer very very sharply (not hard, but very swiftly). That will create the shock pressure wave you need to pull the bearing out and should not allow enough time for the grease to squeeze through the seals. Make sure there's grease all the way to the top.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 10-25-2014, 01:31 PM   #19
Talking
If you want to use niznai's method, then using 2.5million cst lube will make more sense, or using ofna diff lock lube....
Old 10-27-2014, 10:00 AM   #20
It took a propane torch to get it out. But first, all the grease I had packed into it dripped out and landed on my fingers making nice blisters.
What a bad design. All they needed to do was make a through hole so you could drive the bearing out from the back side.
Old 10-27-2014, 10:50 AM   #21
Smile
I think the New Novak motors have the hole in the back like you suggested... Sorry about the blisters, I have a few of mine too....lol........ I think that design was adopted to keep dirt out....
