Old 10-19-2014, 06:01 PM   #1
Default KO Propo Shorty Servo
Fellas,
For touring car; what's the best KO shorty servo available? Model number(s) and personal experience appreciated.
Cheers and thanks.
Turillo is offline   Reply With Quote
Old 10-19-2014, 06:51 PM   #2
They have two "top end" models
- RSx one10 Response
- BSx2 one10 Response
Both are under 0.10 speed and capable of 7.4V.
The latter uses a brushless motor and has a little more torque (7kg vs 10.5kg at 6V).
And is more expensive.
Either are up to task. Money no object, go brushless, it's a fairly new servo (released only a couple of months ago) so finding real world experiences might be hard.
It has the right specs and would be typical KO quality though, unlikely to go wrong.
cplus is offline   Reply With Quote
Old 10-19-2014, 07:52 PM   #3
KO have Power and Response. Which one should be better for TC?
TamiyaW1688 is offline   Reply With Quote
Old 10-20-2014, 02:27 AM   #4
For electric TC the torque of the response series (especially the brushless one) is more than adequate.
If it was nitro/foam then you might sway to the power one.
Old 11-03-2014, 03:14 PM   #5
Alexzheng028's Avatar
Can you still run the power one ten bsx2 in a electric TC setup? I currently was using a BB Hitec servo which was around 25$ on ebay. Now I just recently bought two BSX2 Servo. One response which is the standard size one. And the one ten power. Now my car does not seem to be controllable. I will post a video when i can. My main question is, How exactly does a servo show signs of needing replacement. My my power one ten seems to have a weird sound similar to the cheap 20$ servo. So that gets me also wondering this next question. What is the difference between my cheap servo and my k.o.propo? Because So far I havent even seen the difference..(maybe its because my drivetrain or trans is messed up??)
Alexzheng028 is offline   Reply With Quote
Old 11-03-2014, 03:15 PM   #6
I am over steering @ 3mph....
Old 11-03-2014, 04:19 PM   #7
JayL's Avatar
The BSx2 one10 Response is an amazing servo, fast, tons of holding power and very precise "feel" and the brushless motor will last longer and run cooler, as do all brushless servos
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-03-2014, 11:18 PM   #8
did u buy the KO Propo new or used?
Gomnadz is offline   Reply With Quote
Old 11-04-2014, 06:18 AM   #9
orcadigital's Avatar
Trader Rating: 61 (100%+)
I have an RSX One Response in my mod touring, and run PDS2413's in my stock touring and USGT cars. The RSX is awesome, but the 2413's are a lot cheaper and have been amazing reliable as well. The 2413's I bought used, the RSX new. No problem on anything from Fwd USGT 21.5 to asphalt mod touring.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 11-04-2014, 06:29 AM   #10
Trader Rating: 77 (100%+)
I just bought the 30205. Will try it this weekend.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 11-04-2014, 07:48 AM   #11
Just ordered the BSx2 one10 Response Shorty...look forward to using it. I'm sure it wont dissapoint.
Thanks for all the replies Fellas
Old 11-04-2014, 08:38 AM   #12
Thanks to Cplus,
Just got the BSx2 one10 Response, it is much smoother than Savox on the bench. will try it on the track later this week.
Tamiya Fan
Still have: TB-03, TA05V2, TA06, M05, F201, F104V2, FF01, FF03, Jeep, TXT, King Hauler with oil tanker trailer.
And, TC-3 and Pro 2
Old 11-04-2014, 08:45 AM   #13
did u buy the KO Propo new or used?[/QUOTE]
I bought 2 BSx2 from RCmart. Should be new, as I am new to the hobby. I am either hearing things, or both my bsx2 is making a gliching sound.
Old 11-04-2014, 09:17 AM   #14
What radio gear are you using. You may have to tern the steering curve down on your hand set. So the response is slowed down. And make sure when the radio is turned on the wheels on your car are both pointing in the right direction and going dead straight without any input from the radio.
big paul is offline   Reply With Quote
Old 11-04-2014, 12:54 PM   #15
I bought 2 BSx2 from RCmart. Should be new, as I am new to the hobby. I am either hearing things, or both my bsx2 is making a gliching sound.[/QUOTE]
ok...they should be new.
next question.... what radio and receiver are you using?
