Old 03-22-2016, 09:15 PM   #691
kewdawg's Avatar
Originally Posted by fanfor18 View Post
I need some setup help as I am looking to gain corner entry steering. I am currently running Ryan Maker's basic asphalt setup with a couple of changes. First, I am running the F00 front block so no arm sweep, second I am running 2.5 degree of rear toe, and finally I am running 5K in the diff. At the race this weekend it just looks like the faster guys are able to drive in deeper and just turn, where as I would have to tap the brakes and still slow down sooner to make the same turn. Thanks for any help.
Forgot to mention that I am running on medium grip asphalt.
It sounds more like the rear has too much grip. Try reducing the rear toe to 2°, raise the lower roll center by adding shims (1mm)under the rear suspension blocks(remember to readjust the droop and ride height) and lowering the rear shock positions on the shock tower (start laying them down).
kewdawg is offline   Reply With Quote
Old 03-22-2016, 09:22 PM   #692
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
More corner entry? On top of what has been said, lessen the front droop, stand up the rear shock a bit.
I prefer 2.5 toe to 2 myself, but its worth trying as long as the car doesnt over-rotate.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 03-22-2016, 09:31 PM   #693
kewdawg's Avatar
You can lengthen the rear wheelbase by moving shims to the front of the rear arm to reduce rear grip helping the car to rorate, also. There are several ways to attack the problem.
Old 03-23-2016, 08:05 PM   #694
Everyone,
I appreciate all of the input. I now have a list and need to get to testing
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 04-08-2016, 05:05 PM   #695
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
New Guy looking for a neutral asphalt (smooth) setup to try out.
Kenny
TRCR, ARC r11 TC, hobbywing V3.1, TLR 22SCT™ 2.0, Team associated b6 buggy, futaba 4PX, Axial Wraith, Glamis Uno, Icharger 308, Simple Green, USMC
kjohnsiii is offline   Reply With Quote
Old 04-08-2016, 05:26 PM   #696
GasGod's Avatar
pettit rc has some good setups the box setup is pretty good
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-08-2016, 06:31 PM   #697
kjohnsiii's Avatar
Thanks GasGod
That was the first place I looked can you recommend one? I also forgot to mention that I am running a 17.5. Does that change things?
Old 04-08-2016, 08:24 PM   #698
This is a good starting setup
http://site.petitrc.com/reglages/vbc...cAsphaltSetup/
Brandon Smith
Old 04-08-2016, 10:01 PM   #699
kjohnsiii's Avatar
Thanks I will check it out.
Old 04-08-2016, 10:40 PM   #700
kjohnsiii's Avatar
Another quick question
What size are the little set screws that secure the belt cam adjusters? None of my metric wrenches seem to fit (weird).
Old 04-08-2016, 11:08 PM   #701
R3VoLuTiOn's Avatar
I use both 1.5mm and 1/16" for them.
you can also undo the 4 screws holding the top bulkheads to set belt tension and centering
Old 04-09-2016, 12:16 AM   #702
kjohnsiii's Avatar
Thanks John I'll take a look again. I ended up removing the upper bulk head to adjust the belts.
Old 04-19-2016, 05:23 PM   #703
kjohnsiii's Avatar
Thanks Brandon for the setup recommendation. Had a chance to try it out the past few days and it works well. Made a couple of tweaks to the rear end and I'm liking it!
Anyone have a used roller for sale? I checked the for sale section with no luck..
Old 04-20-2016, 07:26 AM   #704
Good to hear that setup worked. I use that setup with just minor tweaks also. I was in the same boat with wanting to find a 2nd D07 and could not find any. I came across Alex Pate, the owner of gripworks RC, and he happened to have a car he ended up selling me. I would recommend hitting him up and see what he has. PM him he gets responds quickly.
Brandon Smith
Old 04-20-2016, 08:22 AM   #705
AlexPate's Avatar
Trader Rating: 19 (100%+)
Unfortunately I'm fresh out of roller chassis, I do have a new d08 (far superior imho) and a new ghost evo rm (still a great car)
Lots of d07/08/ghost evo spares though
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
AlexPate is offline   Reply With Quote
