Old 11-24-2015, 02:35 PM   #646
Default do7 and d08 news letter
http://www.vbcracing.com/pages/vbc-racing-newsletter
hi found this look like a few new bits, also mi5 micro caster block idea in one pic which i really like (last two car where mi5 and evo )
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 11-25-2015, 03:46 PM   #647
Default vbc front dynamic type r belt
Why is this belt to big? Its says its for the the wildfire d06 d07
bigtee01 is offline   Reply With Quote
Old 11-25-2015, 08:21 PM   #648
VBC Dynamics Front Belt Type R B-03-VBC-0013-512
This Belt for Wildfire D05 Only...
D06/D07 should be WildFireD06 Front Belt B-03-VBC-3001
and Rear WildFireD06 Rear Belt B-03-VBC-3002
Yokolun is offline   Reply With Quote
Old 11-26-2015, 08:17 AM   #649
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Hello, I am new to on road and recently bought a used D07 from a buddy.
Would like to get some advice on maintenance for this car. What should I be staying on top of. I know there is probably a thousand things that I can do but any advice would be appreciated.
Kenny
TRCR, ARC r11 TC, hobbywing V3.1, TLR 22SCT™ 2.0, Team associated b6 buggy, futaba 4PX, Axial Wraith, Glamis Uno, Icharger 308, Simple Green, USMC
kjohnsiii is offline   Reply With Quote
Old 11-26-2015, 08:51 AM   #650
Akhor's Avatar
Kenny
If you bought the kit used, I suggest rebuilding the shocks and diffs. As well as checking all the bearings.
Other then that.. Same with every car. Check that the screws are tight and replace broken parts.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 11-26-2015, 10:13 AM   #651
kjohnsiii's Avatar
Thanks!
what about the belts, how do I check them?
Old 11-28-2015, 07:12 AM   #652
kewdawg's Avatar
Thanks!
As the belts wear, the teeth flatten. Don't run them to tight or too loose. If, you're running mod, adjust so there isn't a lot of give when you poke it. If, you're running stock, just loose enough too not skip under power. This should ensure a smooth / free drivetrain and months of driving without replacing them.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 11-28-2015, 07:21 AM   #653
godzukihop's Avatar
Trader Rating: 31 (100%+)
You holding back on the good advice AGAIN!??
Don't forget that corner speed tip.
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-28-2015, 07:42 AM   #654
kjohnsiii's Avatar
Thanks, running stock 17.5. So I'll take your advice on the belts!
Old 11-28-2015, 08:21 AM   #655
kewdawg's Avatar
That's a closed meeting conversation for VBC owners. You are not privileged to hear such things. #choosebrandswisely
Quinn Moon
Old 11-28-2015, 08:25 AM   #656
kewdawg's Avatar
Thumbs up
Hope it helps and happy racing!
Quinn Moon
Old 12-05-2015, 02:35 PM   #657
are there ball diffs for the vbc wildfire D06 if so what are the part #'s
steve100 is offline   Reply With Quote
Old 12-05-2015, 04:14 PM   #658
Fredp1's Avatar
Only gear diffs AFAIK
Fredp1 is offline   Reply With Quote
Old 12-05-2015, 04:27 PM   #659
Fredp1's Avatar
Default D08 announced
VBC have announced the D08.
http://www.vbcracing.com/products/wi...-d-05-vbc-ck20
Old 12-05-2015, 06:55 PM   #660
Cam someone post info on how to set up sway bars? I will be racing on a high traction carpet surface.
I have the red bars that come with the kit.
Should I run them or not.
How should I set them up?
tekin112000 is offline   Reply With Quote
