Old 08-30-2015, 07:40 AM   #571
Originally Posted by RollingChicane View Post
I have both the D06 and D07 and can say that they are both very good chassis's. There should be no reason that you cannot get the D06 working great. I would recommend to save your money and focus on your setup.
What class, tires and surface are you running?
Crc carpet setting the car up for 21.5 class will be running usgt tire gravity rc premounts
bigtee01 is offline   Reply With Quote
Old 08-30-2015, 09:42 AM   #572
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I have seen a few comments / questions for folks that have tried the ARTS. I have been running my D07 for about 1.5 years and have been pretty successful with the car. I run USGT on carpet. I played around with the ARTS for about a month before I switched back to the standard rear toe blocks.
The ARTS definitely freed up the rear of the car more than the fixed toe blocks but I found the car to be a bit unpredictable at times.
After about a month of working with the ARTS and feeling I had a decent handle on the car, I ran the first round with ARTS, swapped over to the fixed toe blocks for the second round and found my times to be around 0.07 - 0.1 faster across the fast lap and top 5, 10 laps but .2 faster on my top 20 laps.
In the end, I felt more consistent with the fixed rear toe blocks than the ARTS on our low grip carpet track.
I definitely don't think the ARTS is a "must have" option and I definitely think it is more beneficial on a high grip surface. It was fun working with it and if you are looking for something new to tinker with, I think you would enjoy it. But, I wouldn't expect to bump up to the podium simply due to adding this to your car.
These are just my observation points from my specific experience. Hope this helps someone.
There is an advantage you can use with the ARTS. You can run forward arm sweep and readjust your rear toe in with the ARTS, this arm sweep forward allows the axles to push downward under excelleration for more traction. Rearward arm sweep does the opposite. Its something you can try on your next outing.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-30-2015, 06:30 PM   #573
I have the aggressive package and I think the belts are different.
But I'm going to try the normal belts since the motor mount is only 1mm rearwards, we should be able to adjust to a good tension using the tension setting rings on the diff/spool.
Originally Posted by hasse85 View Post
is it the same belts to the Aggressive chassi and the standard?
Ted Su(TW) is offline   Reply With Quote
Old 08-30-2015, 06:34 PM   #574
Default front drive shaft
What other options are people using? I find that the vbc front drive shaft don't hold up. I guess maybe hudy.
Old 08-30-2015, 08:05 PM   #575
I am using TM (team magic) and I like them better.
I usually rebuild them after about 15 packs of batteries, and they last like ...forever.
Hudy is as good, but they are pricy.
Old 08-30-2015, 10:53 PM   #576
midse's Avatar
Default Dcj
Use lithium grease spray on the DCJ before assembly, especially on the kit DCJ. They're not too bad if maintained.
Roche-NLA
Radtec- superseded Roche and they seem to have more bearing slop
Arrowmax- appear to be the same as Radtec
Race-Opt (Team Powers) seem to be similar to Roche.
I'm still running a pair of Roche DCJ and hardened front outdrives that have raced about once a week for 2 years. Very minimal wear.
midse is offline   Reply With Quote
Old 08-31-2015, 12:28 AM   #577
Any one tried "bending" a bent one piece motor mount back to perfect shape ?
Any good suggestions?
Old 08-31-2015, 12:35 AM   #578
midse's Avatar
Originally Posted by Fredp1 View Post
67/35 in 48 pitch will give you 3.35.
The Xray offset, RW and ARC/Team Titan spurs work well too.
Race Opt. ( Team Powers ) spur gear have been a good fit.
Old 08-31-2015, 05:39 AM   #579
thank you for the answer
NettoRc Sweden
Team AE B6
MuchMore Racing
Advance Electronic's
hasse85 is offline   Reply With Quote
Old 08-31-2015, 05:55 AM   #580
I'm a little confused as to what type of issues people have with the dcj's in the vbc cars?
I run mod indoor and outdoor and have had the same set of dcj's in my car for over a year.
They have almost zero slop even after a year of mod racing.
Josh Hohnstein is offline   Reply With Quote
Old 08-31-2015, 07:35 AM   #581
patorz31's Avatar
I think they had a bad run of heat treating on some sets. I have the original set in my D06 that I have run for 2.5 seasons. The first 2 sets I had in my D07 broke on the dogbone shaft side. The socket, that the ball in the axle end fits in broke. the last replacement set works fine and has been in the car for 6 months.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 08-31-2015, 09:04 AM   #582
Johnny Wishbone's Avatar
Same, .
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 09-01-2015, 10:20 AM   #583
kewdawg's Avatar
No DCJ issues. One break in almost a year of running from a hellacious crash and still no slop. Keeping them lubed keeps wear at bay.
kewdawg is offline   Reply With Quote
Old 09-06-2015, 10:05 AM   #584
Default Setup UK Tarmac
Hi I am looking at getting one of these cars to race is there any good setups for UK med/high grip Tarmac
tcboy1983 is offline   Reply With Quote
Old 09-08-2015, 03:52 PM   #585
celt's Avatar
Default Ok...what's the deal with this kit?
Quality as best I can tell, on par with the Yokomo and others (BD7 2015 was what I was considering).
Floating layshaft, similar to the BD7.
Dual joint front axles, BD7 add.
Floating servo mount, BD7 add.
Floating steering rack, third party for BD7.
$369.00?? Seriously? WTF?
This kit is just a few dollars more than the Spec-R R2.
http://vbcracingusa.com/store/car-ki...ldfire-d07-kit
Am I missing something? Why so cheap?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Fast410
