Old 06-07-2015, 06:00 PM   #481
Anyone tried those white low friction belts on the D07? If so, which brand will fit?
Ted Su(TW) is offline   Reply With Quote
Old 06-08-2015, 10:21 PM   #482
Originally Posted by patorz31 View Post
Does anyone know if Yokomo Suspension holders will bolt on the D07 Chassis? I was thinking of getting this.
http://www.excelllab.com/#!/cdql/!/A...668/category=0
The only piece of the puzzle that would make the car absolutely perfect.
One-piece suspension mounts will fit. The separate mounts from Exlab I donīt know. I only tried original yokomo separate suspension mounts and they donīt fit D07.
desaix is offline   Reply With Quote
Old 06-09-2015, 06:32 AM   #483
patorz31's Avatar
Thanks, I was think of getting Bezerk Rc to custom cut me a chassis with the Yokomo suspension mounting holes.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-12-2015, 01:38 AM   #484
Found the perfect tool for droop, a Revolution Design ride height gauge for buggy:
Old 06-12-2015, 02:29 AM   #485
Lonestar's Avatar
make sure you end up with the same track width...
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 06-17-2015, 12:48 PM   #486
Default Steering rack
The d06 steering rack is quite sloppy, I tried to shim it up but it never really got any better. The d07 seems to have a new steering rack but is it still sloppy?
matt31313 is offline   Reply With Quote
Old 06-17-2015, 01:01 PM   #487
patorz31's Avatar
Mine has some play after a year but nothing worth worrying about. My year old xray has about the same amount of play.
Old 06-17-2015, 02:34 PM   #488
Fredp1's Avatar
I found the bearings to be the main cause. A simple solution is to take the bearings out, put some lunch cling wrap/ Glad wrap, in the steering arms, then insert the bearings. Just cut the excess cling wrap. The bearings will then be a snugg fit. If it's still loose, do the same for the steering post before you put the arms on.
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 06-19-2015, 03:24 PM   #489
Thanks will give this a try
Old 06-27-2015, 06:59 PM   #490
Do any other brand outdrives work on the D07 spool? I ordered the hardened lightweight ones but was looking to see if something else would work until they got in! Thanks! Potentially I could also just use a whole different spool assembly if anyone has done this before.
AZ Militia is offline   Reply With Quote
Old 06-28-2015, 03:17 AM   #491
scoyle's Avatar
Who would be considered the 'big' names running VBC at the minute?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 07-01-2015, 07:06 AM   #492
Lonestar's Avatar
Lucas Urbain in Europe, multiple ETS A-main mod finisher, is probably the brand's flagship driver for the old world continent...
Not sure about RoW.
Paul
Old 07-01-2015, 07:27 AM   #493
patorz31's Avatar
Dave erlich in the states.
Old 07-04-2015, 10:39 PM   #494
Texco's Avatar
Hey all,
Just a quick question regarding droop set up, if Ryan Maker's setup is 5.5 and 1.5 Droop is that 5.5 and 1.5mm above ride height or is that on setup blocks?
Thanks in advance
Texco is offline   Reply With Quote
Old 07-05-2015, 02:20 PM   #495
haura415's Avatar
Originally Posted by Texco View Post
Hey all,
Thanks in advance
haura415 is offline   Reply With Quote
