Old 05-05-2015, 05:43 AM   #436
I'm running LTC-R, 4.5t modified.
I think the straights are ok. I'm looking for more mid corner to corner exit.
Thank you!
Originally Posted by theproffesor View Post
What body are you running? What class / size motor? You could need a gearing change. Are you trying to push the limit on the straights or through the infield? do you want to gain corner entry or corner exit speed? There are many factors that go into "push the car to the limit". We need to know what limit you are referring too.
Ted Su(TW) is offline   Reply With Quote
Old 05-05-2015, 07:49 AM   #437
patorz31's Avatar
Ok can anyone explain the advantages of using raised towers and longer springs over the stock setup. Why would I want to, and when would I want to?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 05-05-2015, 08:21 AM   #438
Lonestar's Avatar
cannot disagree with that question being asked as I asked the very same one 3 posts ago
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 05-05-2015, 08:45 AM   #439
patorz31's Avatar
This is what Lucas Urbain posted on facebook to my question.
"Higher shock towers will raise the center of gravity, making the car roll deeper. As a result you get a bit more traction and rotation. It will also give a more aggressive feel to the car.
Still early testing though..."
Old 05-06-2015, 12:52 AM   #440
Lonestar's Avatar
cheers man. I killed my FB account a few months back, I'm missing on some of the action
Phil... if you read this... your comments are welcome
Paul
Old 05-06-2015, 03:54 AM   #441
no time, short answer :-)
I suspect, that in a given damper and for example a constant shaft speed the damper force increases near the end of the possible shaft motion.
The damper force surely occurs because of viscous friction. But this does not only happen at the holes of the piston and the slot between piston and cylinder side wall. The is also viscous friction created by the mass flow in the relative chambers (over and unter the piston). When the upper chamber (on bump) or lower chamber (on rebound) becomes smaller the "chamber-internal" fluid friction increases.
The shorter damper acts more progressive in his damping effect when the piston almost moves to the bladder (i'm not mentioning progressive force over increasing shaft speed).
Now what has that to do with RC damper length?
When racing on low grip, you want as much as possible, so you want as less wheel load alteration as possible which can be achieved by using a as linear as possible wheel rate. (i have read, that the HPI Silvers are quite linear/less progressive as others maybe thats why they "feel" so good on the track).
If someone wants to take a deeper look, just look at things like jacking forces because of progressive wheel rate or roll center possition.
Longer dampers seem to be better on lower grip just by watching, what the pro drivers are using. And in my created theory (@freak) i can explain why.
So lets use offroad dampers (ROFL).
Back to honesty: I think there is an effect but it is small.
Phil
PS: Back to exam...
Worst87 is offline   Reply With Quote
Old 05-06-2015, 09:19 AM   #442
Viscous.
Rodney Racer is offline   Reply With Quote
Old 05-06-2015, 09:37 AM   #443
Corrected, thanks
Old 05-06-2015, 06:34 PM   #444
Hi
What other brand belt fits on this kit?
hilmircc is offline   Reply With Quote
Old 05-11-2015, 07:43 AM   #445
patorz31's Avatar
Ok take a look at the way this VBC chassis appears to be cut.
Why would you?
Old 05-12-2015, 02:31 AM   #446
Lonestar's Avatar
because you want to save a chassis that's been partially delaminated on the side and you feel that as long as it holds in one "piece" it can still do the job.
or maybe because it's just plain broken
Anyway, I wouldn't
Paul
Old 05-12-2015, 03:27 AM   #447
Lonestar's Avatar
New "lo-light conditions" body... simplistic, but still
Edit... crap, fluo doesn't show that well...
Old 05-12-2015, 03:52 AM   #448
Lonestar's Avatar
Phil
PS: Back to exam...
I love it
Old 05-16-2015, 01:04 AM   #449
FIzZFunG is offline   Reply With Quote
Old 05-16-2015, 04:56 AM   #450
Fredp1's Avatar
Hi Paul,
Can you share how did you mount the 3rd front body post?
Thanks Fred
Fredp1 is offline   Reply With Quote
