Old 10-27-2014, 07:04 PM   #31
RC Passion's Avatar
Originally Posted by theproffesor View Post
So it was mentioned that one of the new things will be "harder" plastics. Does this mean stiffer (more brittle), or was this meant to mean stronger. After the upgrade to the V2 suspension parts, I am not seei g a need for a return to harder plastics. I broke several V1 C-Hubs, spindles and arms on my Ghost and D05. After I changed all the parts over on my Ghost, and got the D06, I have a bunch of spares I have yet to use. My car handles great on carpet, is very durable, and I thought you would want more flex for low traction asphalt. So why the need for "harder" plastics?
The 06's have super soft suspension plastics. Softest I've ever seen. Coming off a rough round I'd surely have to check on droop and camber settings as these don't hold very well. Yeah, better for grip, but I'd like to see medium plastics at least in arms and tie rod ends. Hopefully the 06's can use these new parts...
VBC
RC Passion is offline   Reply With Quote
Old 10-28-2014, 02:18 AM   #32
chasingthepack's Avatar
they need to hurry up and release it,if its not out in a week then ill be sticking with xray
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-28-2014, 02:24 AM   #33
The D07 come with extra hard plastic parts. Even the D07 parts had revised suspension geometry but they the arms, c hub, upright can still fit the D06.
rc-man is offline   Reply With Quote
Old 10-28-2014, 02:43 AM   #34
theproffesor's Avatar
Trader Rating: 56 (100%+)
New geometry huh? That means the new parts are different from the old material and design. How long are they going to keep parts support up for the 06?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-28-2014, 07:20 AM   #35
DBM
It is possible to change the geometry while keeping the same plastic parts. I'm not sure if this is the case with the D07, but If the plastic parts are interchangeable, they very well could be the same parts.
To change geometry, the easiest way to do it is to change the lower suspension mounting block locations and Heights, as well as the position of the upper inner camber link mount on the bulkhead. Perhaps this is what VBC did. Hopefully more detailed info on the changes between the D06 and D07 surface soon.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 10-28-2014, 03:47 PM   #36
As I know until now, D07 has been chaged upper bluk whole (4 to 2) and location also rear hub whole (2 to 1) , changed shock tower ( different shape but don't know they change the height. ) I have some picture but I can't update here.
So please wait for a while.
accord12 is offline   Reply With Quote
Old 10-29-2014, 01:11 AM   #37
Jimmy Maddison won the first round of the EWS 13.5 blinky class - the UK's biggest carpet winter series - with a D07. There's a photo of the chassis too:
Smddirect.co.uk/index.php?_a=viewnews&news_id=64
Sorry didn't have a high enough post count to post the URL properly.
matt31313 is offline   Reply With Quote
Old 10-29-2014, 04:29 AM   #38
Are they changing the shocks too? Even if he black annoed them, they dont look right
Old 10-29-2014, 07:33 AM   #39
Yokomo shocks on Jimmy's car
nicoo2k4 is offline   Reply With Quote
Old 10-29-2014, 07:55 AM   #40
patorz31's Avatar
On RedRc: http://www.redrc.net/2014/10/vbc-rac...uring-car-kit/
Features:
– Floating steering system
– Inline CNC 7075 aluminium alloy one piece motor mount system
– Zero Tolerance Pulley system
– New centre arm mount with adjustable flex setting, ready for rear active toe system (sold separately)
– New roll bar system for easy tweak adjustment
– High quality CNC 2.5mm carbon fibre chassis with 2.0mm carbon fibre upper deck
– New suspension geometry for more front and rear traction
– Ultra smooth rear gear diff with lightweight front spool
– All new 3.5mm carbon fibre lightweight shock towers
– TBB big bore shocks
– Front dual joint driveshafts
– Lightweight 1-piece inline mounted steering servo mount with integrated antenna mount
– Lightweight CNC aluminium alloy belt tensioner
– New carbon composite Rear Suspension Upright V2, WildFireV3 Suspension Arms, Steering Block V3
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-29-2014, 08:12 AM   #41
I like the sway system. Just converted my Ghost and 06 with are parts. Are the shock towers lower/higher/holes in different spots? Whats the difference is the V2 rear hubs, and V3 arms and steering blocks from their predicessors? But it looks good overall. Price ???
Old 10-29-2014, 08:18 AM   #42
Also I've been wondering since my first D05. What the poop is the inner hole for on tbe rear arm. Seams like they thought about attaching a sway bar there, but decided not to. If changing the molds for the arms why not get rid of it if its not used?
Old 10-29-2014, 10:23 AM   #43
patorz31's Avatar
Here is the pic:
Old 10-29-2014, 12:53 PM   #44
Cadman1981's Avatar
Does the D07 come with "shorty" shocks?
In that pic, they are the yokomo longer shocks...I am new to VBC, do they offer a longer set or will, since a lot of companies are reverting back?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 10-29-2014, 01:25 PM   #45
patorz31's Avatar
The one in the pic above is Jimmy Maddison's prototype that he had at IIC and used to win the Super Stock class at the Essex Winter Series in the UK. His car is slightly different than the production D07 from the look of the pics.
