Old 03-16-2015, 10:07 PM   #331
Regional Moderator
disaster999's Avatar
Thanks for the replies. But if according to mupchu, if there are 3 ways of measuring droop, how would I know which method was used on the setup shit posted by the pros? Im assuming its done by measuring under the arms front and back.
disaster999 is offline   Reply With Quote
Old 03-16-2015, 10:42 PM   #332
usually they notate how on the sheet.
+2mm over ride height . . they measures by lifting the chassis.
sometimes you will see two numbers 5,9 the lower number is the bottom of the arm, the higher number the center of the pin.
mupchu is offline   Reply With Quote
Old 03-16-2015, 11:11 PM   #333
Regional Moderator
Thanks. That helped.
Old 03-21-2015, 11:20 AM   #334
kewdawg's Avatar
How do you measure at the center of the pin?
kewdawg is offline   Reply With Quote
Old 03-22-2015, 06:03 PM   #335
Regional Moderator
place the car on a flat surface, wheels off, shocks disconnected, and use a ruler or calipers and measure from the surface to the center of pin.
Old 03-23-2015, 11:10 AM   #336
kewdawg's Avatar
Got it. Thanks.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
Old 03-23-2015, 01:45 PM   #337
TomTurbo's Avatar
brandnew: http://www.fast-webshop.com/tonispor...essive-Package
but not for low grip conditions as i thought
VBC Wildfire D07
Sworkz S104 Evo
TomTurbo is offline   Reply With Quote
Old 03-23-2015, 08:14 PM   #338
kewdawg's Avatar
When is it expected to hit the states?
Quinn Moon
Old 03-23-2015, 09:46 PM   #339
theproffesor's Avatar
Trader Rating: 56 (100%+)
So it basically moves the motor back to D05 position? Interesting.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 03-27-2015, 03:28 AM   #340
Lonestar's Avatar
Hi folks, just landed a killer deal at the LHS on a D07. I've only heard good things about the car, and this opportunity was too good to pass... Currently driving a BD7 '15, I will run both cars in parallel (at least at the beginning) as I have enough electronics to get both equipped
Anything I should know, or no-miss parts I should get? We run 13.5 boosted indoors on very hi-grip carpet... The aluminium chassis is already on-order. we'll see later about the "agressive" chassis discussed above...
Thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-27-2015, 03:42 AM   #341
Thanks!
Paul
Hello!
What u really need :
C05 Suspension mount
C10 Suspension mount
That's all i'm using.
A last ETS, a lot of drivers switch back to carbon chassis. Faster and more easy to drive...
I'll try aggressive package soon at Luxembourg for ETS. So can't talk now
On petitrc, you can find some of my setups for high traction carpet. And,as u are french, if u need setup advice, you can contact Lucas. Je crois que tu dois le connaître : ))
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 03-27-2015, 09:42 AM   #342
Airwave's Avatar
I used your setup last week on the same track as Lonestar and it was very surprising... Very far from the setup I've built after many trainings but working better than mine!
The most interesting fact was the roll-center, I was used (and a lot of local drivers are also) to run with 1mm under the arms...
Did you already try the ARTS kit?
Airwave is offline   Reply With Quote
Old 03-27-2015, 03:04 PM   #343
Not for the moment. Maybe for outdoor. Nobody aware using ARS during outdoor!
0mm under arms is always faster! Not always easy in fast change direction.. U need to run really smooth!
Old 03-27-2015, 06:28 PM   #344
NITTO550's Avatar
Quinn fist you won't get off that color scheme and now you want my car ? Smh.
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 03-27-2015, 07:57 PM   #345
kewdawg's Avatar
Lol! Hey, I figured someone's gotta show you how to drive it fast. Oh, yeah - my paint scheme is off limits, too.
Quinn Moon
