Old 03-12-2015, 06:27 AM   #316
patorz31's Avatar
Originally Posted by Korey Harbke View Post
Looks like Jimmy's car. I wire mine up exactly how he does. Heck... I even have all of the same electronics!
Jimmy Madison? Doesn't he drive a Yok now?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 03-12-2015, 07:31 AM   #317
Originally Posted by AZ Militia View Post
That is clean looking setup! How do you like the ORCA speedo? Is it the V3? I was thinking about replacing my Hacker with it.
Sorry not my car. Just the best example of a VBC with a transponder attached to a RX I could find!
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 03-12-2015, 08:10 PM   #318
Originally Posted by kewdawg View Post
Guys, my steering assembly moves freely, full lock, left and right, but binds up to almost no movement with the TJDs (Two-Piece Joint Drives) installed. I removed them and noticed, that, if you move the axle left and right to simulate steering, the inner axle moves in the opposite direction. I believe this is causing the binding when installed in the car. Has anyone else experienced this problem? Is there a fix???
I do not know this car at all, but I have seen this happen before. Not knowing how your double joint looks like, I can just point out that the pins must be aligned. So the small pins should point to the same direction and not cross wise, if you know what I mean. Otherwise they bind up...
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 03-12-2015, 10:12 PM   #319
frank b's Avatar
that servo saver on the d07 can someone get me a part number for it.. I know it's a Durango
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 03-13-2015, 04:18 AM   #320
NITTO550's Avatar
Xray 4 spring servo saver is good too
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 03-13-2015, 07:18 AM   #321
kewdawg's Avatar
Cool. Thanks for the info. 😊
kewdawg is offline   Reply With Quote
Old 03-13-2015, 07:40 AM   #322
kewdawg's Avatar
http://www.rcplanet.com/mobile/Product.aspx?id=119353
Old 03-13-2015, 07:41 AM   #323
S.Stew's Avatar
It might be this:
http://www.amain.com/team-durango-hd...-saver/p297945
They work really well and are ~1/3 the cost of the Xray.
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 03-13-2015, 07:50 AM   #324
theproffesor's Avatar
Trader Rating: 56 (100%+)
Do you have the 5x8x3 bearings on the inner side of the steering block? Also you may want to put a .1 or .15 shim between the outer bearing and the axle pin. Also Mark sure your c hubs aren't on backwards. This would cause the dcj's to hit when turning.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 03-13-2015, 12:45 PM   #325
kewdawg's Avatar
bearings and c-hubs were good.
Old 03-13-2015, 08:47 PM   #326
NITTO550's Avatar
Does any other brand belt fit this car?
Rich D..
Old 03-16-2015, 10:09 AM   #327
duggyload's Avatar
Default ARTS
Has anyone else started running the active rear toe ?
We ran it this past weekend and it really makes a difference.
Rear of the car feels more predictable .
Anyone got any comments or tips
One thing I did notice is that the grub screw in the aluminium c hub does not
hold the hinge pin in very well
duggyload is offline   Reply With Quote
Old 03-16-2015, 08:16 PM   #328
Regional Moderator
disaster999's Avatar
Question on droop setting. I used to race 1/12th and never really need to use droop gauges before, so Im not sure where to measure it on the D07.
Im guessing you measure the droop from the lowest part of the suspension on for both front and rear correct? So on the front, you measure from the outer most point of the arm and in the rear, you measure from the lowest point of the hub?
Please correct me if Im wrong
disaster999 is offline   Reply With Quote
Old 03-16-2015, 08:43 PM   #329
people measure droop one of three ways:
* center of the pin on the rear hub
* bottom of the rear arm right under the pin
* measured buy pulling up on the chassis w ride height gauge (measured the diff between ride height and the point where the wheels leave the surface).
https://www.youtube.com/watch?v=GYVcEPO3FME
mupchu is offline   Reply With Quote
Old 03-16-2015, 09:18 PM   #330
Fredp1's Avatar
I use a ride height gauge, with the gauge at right angles to the chassis measuring under the arms.
For the rear droop, the lowest part of the loop.
For the front droop, the rear part of the front arm where you can see the end of the pivot pin used for the c-hub and arm.
(Note The centre of the front arm is lower then the rear/front end of the arm as the c-hub can hang below the arm interfering with the height gauge.)
Hope this makes sense.
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
