VBC WILDFIRE D07 >
VBC WILDFIRE D07
Like Tree4Likes
VBC WILDFIRE D07
Old 03-10-2015, 07:00 AM
  #301
DBM
Sounds like there is a new car coming out to replace the VBC Ghost. I'm curious about when a dynamics edition D07 will be hitting the market.
DBM is offline
Old 03-10-2015, 07:35 AM
  #302
patorz31's Avatar
I had also heard from someone that a Nitro TC may be in the works.
patorz31 is offline
Old 03-10-2015, 08:37 AM
  #303
TomTurbo's Avatar
me too!
i guess the d07 dynamics will be available in summer.
and 3 or 4 months later we will see the d08... this strategy is the only thing i don't like at vbc
except of that i love them
TomTurbo is offline
Old 03-10-2015, 11:07 PM
  #304
Thumbs up
Originally Posted by cplus
Double sided tape to the side of my receiver.
sorta like this
That is clean looking setup! How do you like the ORCA speedo? Is it the V3? I was thinking about replacing my Hacker with it.
AZ Militia is offline
Old 03-11-2015, 12:10 AM
  #305
Fredp1's Avatar
Originally Posted by freebird
New VBC car.
Anyone else heard or know anything? Saw a note about something coming very soon on FB this morning.
Can you post a link where you saw that note?
Fredp1 is offline
Old 03-11-2015, 12:13 AM
  #306
Regional Moderator
disaster999's Avatar
Would the D07 work with normal servos? Trying to save some money and reuse my standard size Futaba servos but not sure if this would severely limit the space for esc/receiver and/or throw the balance of the car. All the setup ive seen uses a low profile servo.
disaster999 is offline
Old 03-11-2015, 02:30 AM
  #307
Fredp1's Avatar
The low profile servos gives you enough room to mount the receiver on the bottom deck. Depending on the footprint of the ESC and receiver, it might not fit on the bottom deck.
Fredp1 is offline
Old 03-11-2015, 05:27 PM
  #308
kewdawg's Avatar
Default binding steering???
Guys, my steering assembly moves freely, full lock, left and right, but binds up to almost no movement with the TJDs (Two-Piece Joint Drives) installed. I removed them and noticed, that, if you move the axle left and right to simulate steering, the inner axle moves in the opposite direction. I believe this is causing the binding when installed in the car. Has anyone else experienced this problem? Is there a fix???
kewdawg is offline
Old 03-11-2015, 06:39 PM
  #309
VBCRacing on Facebook
freebird is offline
Old 03-11-2015, 06:57 PM
  #310
EricPF's Avatar
I run a fullsize servo no problem. Just all depends on the size of your receiver and ESC. I use a KO KR-211 receiver and Hobbywing 3.1 ESC and everything fits fine, with the transponder in between the receiver and ESC too.
EricPF is offline
Old 03-11-2015, 09:55 PM
  #311
whityboy's Avatar
In my last kit I had the same problem, after looking i noticed the c-hud had no beveled side, so when turning the tjd's hit the chub, I dremeld a beveled side in the hub and problem was solved
whityboy is offline
Old 03-11-2015, 10:18 PM
  #312
kewdawg's Avatar
Hey, thanks. Would you please post a pick of what you did?
kewdawg is offline
Old 03-11-2015, 11:21 PM
  #313
whityboy's Avatar
just check if you turn if the tjd hit the chub, and if the chub at the straight side have a bevel, if not dremel one yourself, you can check with new one what i mean
whityboy is offline
Old 03-11-2015, 11:46 PM
  #314
kewdawg's Avatar
I wanted to know how much material you need to dremel out? That's why I asked for a pic. I could not locate one in the VBC USA page in the book.
kewdawg is offline
Old 03-12-2015, 12:43 AM
  #315
Korey Harbke's Avatar
sorta like this
Looks like Jimmy's car. I wire mine up exactly how he does. Heck... I even have all of the same electronics!
Korey Harbke is offline
