Old 02-16-2015, 09:54 AM   #286
Korey Harbke's Avatar
Originally Posted by AlanHall View Post
I'm looking to run it on carpet and just wanted to check if I needed to buy more parts to get it to work
If grip is big race ultra high, I suggest looking into the aluminum chassis.
Otherwise, get some suspension mount shims (to adjust roll centers) and a few suspension blocks. I usually suggest C10, C05, E20 and E25 for people to have in their box.
That gives you options for toe, arm sweep, and overall rear width. These are the blocks I keep in my box at all times, even on asphalt.
Some run Yokomo spring on carpets, and the shock need to be modified a tiny bit to use them (trim the shock bottom about 1.75mm and space shock off tower and arm 2mm). The kit springs work really well though, they make the car feel safer and more stable in my opinion.
Hope that helps.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is online now   Reply With Quote
Old 02-20-2015, 11:07 PM   #287
Microtome's Avatar
Default NEWS FLASH!! Somehow I did not get the Memo
Originally Posted by theproffesor View Post
Nice aluminum hubs. Will they work on the front as a tuning option for less castor? And what is the difference between the active rear toe arms and front arms. They look identical. Why would you mold in the sway bar ball mount that will not be used if its a new part?
Those work on the REAR ONLY, DO NOT buy those unless you plan on one of two things, either running Active rear toe and feel like you will need spares, OR You think they will look GREAT on your Key chain.... Said by, the guy who has the "Coolest, Worthless" key chain at the track.
www.GoodentiteRacing.com
Microtome is offline   Reply With Quote
Old 02-21-2015, 04:48 AM   #288
theproffesor's Avatar
Trader Rating: 56 (100%+)
Are you refering to the arms or hubs?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 02-26-2015, 11:50 AM   #289
fmm
Default Active Toe System Kit
Hi all,
I am wondering if someone has tested the new Active Toe System Kit and what the outcome was.
Has anybody tested it? Which are the conclusions?
Under which conditions the system is recommended? do you think that it would improve the car handling on a large and medium bite asphalt track with fast corners and some technical corners?
Thank you in advance!!
fmm is offline   Reply With Quote
Old 03-02-2015, 08:57 AM   #290
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
I was setting the car up this weekend and noticed something kinda strange. The front end droop seems odd. The C-Hub is limiting the arm from going to full droop.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-02-2015, 09:27 AM   #291
frank b's Avatar
Originally Posted by fmm View Post
Hi all,
I recieved my active toe system a week ago and ran it at our club race this past weekend. I would say I'm very happy with it the car felt very stable the whole day in stock and I haven't tried it in mod yet. With a little bit more testing I think Itll be the ticket for this car.in stock and mod. I have an out of town race this weekend and will give more info when I return, forgot to mention it was run on carpet med grip..
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 03-08-2015, 07:27 PM   #292
Just wanted to get everyone's opinion on what upgrades are worth the $$ for the D07. I already installed the 0.0 rear hubs when I built the car.
Thanks!
AZ Militia is offline   Reply With Quote
Old 03-09-2015, 07:56 PM   #293
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Here is my setup from TITC. Car was really good, just some driving errors by myself cost me a couple more top 10 qualifying runs, and a higher qualifying position We changed quite a few things for the unique track conditions that RC addict has.
Any questions, please ask
http://www.petitrc.com/reglages/vbcr...ddict20150301/
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-09-2015, 08:12 PM   #294
Without looking through the whole thread, what is the internal ratio of the D07? Thanks!
Old 03-09-2015, 08:13 PM   #295
1.9
Old 03-10-2015, 05:40 AM   #296
Anyone? Also, where are people mounting their transponder? With a low profile servo, receiver and ESC there's not a lot of room. I used to mount it on top of the servo but with the one piece mount, there's not really room.
Old 03-10-2015, 06:26 AM   #297
patorz31's Avatar
I just servo tape mine on top of the one piece servo mount. I used to run it out on the bumper, but a nasty collision with a nitro TC during practice ended that idea.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 03-10-2015, 06:32 AM   #298
patorz31's Avatar
Blake
I only seem to notice that when running a huge amount of droop. When running the levels of droop that are on most setups I didn't notice it any more.
Old 03-10-2015, 06:38 AM   #299
Double sided tape to the side of my receiver.
sorta like this
cplus is offline   Reply With Quote
Old 03-10-2015, 06:39 AM   #300
New VBC car.
Anyone else heard or know anything? Saw a note about something coming very soon on FB this morning.
freebird is offline   Reply With Quote
