VBC WILDFIRE D07
#272
Yes to the above and don't forget the Steering Swivel Tubes. I also carry a set of the DCJ shafts, and get a few of the PANARACER spurs from Amain too.
#273
Got the fan mount yesterday, it's an interesting solution. I like it.
Do you use the center screw in the topdeck?
#276
I would say the distance is something about 15mm.
#278
"I would recommend just standard bumper foam...the hard can tweak the car very badly and damage the carbon in a hit. You're better off hurting the bumper. I have the ones without the mylaps mount hole...they are stronger and I would recommend them. But if you need the hole for mylaps i'd just recommend the stock bumper."
#279
Gear diff
Hi wonder if anyone can help. Drove on a medium grip outdoor track this weekend. Car is box setup except for 450 oil all around and 8000 diff oil. Was a very hot day. My problem is the car is terrible for the first minute and a half (oversteer on and off power) then the car starts getting better and by the end of the run the car is great. Could it be that the diff oil is to heavy?
#280
Have a look at Ryan Makers setup. He has that car pretty well dialed
http://www.petitrc.com/reglages/vbcr...cAsphaltSetup/
#281
Haven't driven the car yet but very impressed with the design and quality of the build. Everything fit together well with no hand fitting. Shocks are smooth, drivetrain is free. I'll get first laps next weekend on carpet but really looking forward to running modified asphalt in about a month. Thanks to Dave Ehrlich and Korey Harbke for showing me the car and answering my questions.
#283
Korey and Dave looked pretty good at Snowbirds with the cars. Only upgrades I saw were the aluminum rear hubs. Not sure if they were running a stiffer-than-stock chassis or not. Looked pretty stock to me. The chassis appears narrower than the older version and with the addition of the floating steering rack, the car should generate more mechanical grip which is very useful on asphalt. I ran the D06 in stock on asphalt and it worked well. I'm excited to put this one on the track.
#284
I ran an aluminum chassis in modified at snowbirds, but the grip at snowbirds was extremely high... much higher than I had ever seen anywhere at home.
With that said, the base chassis is actually makes the car very versatile and works well on carpet or asphalt. Just a few tuning parts here and there complete the package to your driving style for either condition.
-Korey
-Korey
