Old 01-22-2015, 10:10 PM   #241
Korey Harbke's Avatar
Originally Posted by dr_hfuhuhurr View Post
Sadly I don't think so. There isn't really a good place to mount it on the new motor mount bulkhead. You might be able to use on that is on the side, but its a lot higher up and I'm not sure everything would clear.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-22-2015, 10:24 PM   #242
sashimi999's Avatar
-Korey
Actually it works but need a bit modification.
You have to grind out the Screw thread of the set hole of fan mount first.
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 01-22-2015, 10:45 PM   #243
Nice! I'll have to try that.
Old 01-23-2015, 01:43 AM   #244
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Guys, there is an awesome new adjustable fan mount coming from VBC very soon! Screws straight to the motor mount on the D07 and can accommodate 30-40mm fans, it's pretty cool!
Stay tuned...shouldn't be long
Ryan
Awesomatix - Muchmore - Silverback - Roche - Radtec - LeeSpeed - Protoform - Futaba - Hiro Seiko - SG PitDesign
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 01-23-2015, 04:42 AM   #245
sashimi999's Avatar
Finally released. ARTS system
http://www.vbcracing.com/collections...-d-05-vbc-0183
::Michael C::
Old 01-23-2015, 05:03 AM   #246
theproffesor's Avatar
Trader Rating: 55 (100%+)
Nice aluminum hubs. Will they work on the front as a tuning option for less castor? And what is the difference between the active rear toe arms and front arms. They look identical. Why would you mold in the sway bar ball mount that will not be used if its a new part?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-23-2015, 05:33 AM   #247
patorz31's Avatar
I think the rear arms are from the same mold they just have the one spot where there is a blank spot for a hole drilled.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 01-23-2015, 06:39 AM   #248
Whoooooops. That should be Hole #2 on the rear arm. Let the jokes fly in.....
Heh....hole 2....
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 01-24-2015, 11:03 AM   #249
evostyle's Avatar
Trader Rating: 102 (98%+)
Who has the best price on a NIB D07?
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 01-24-2015, 03:17 PM   #250
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Decided on the D07 over the BD7 and XRay. The price was just too good to pass up here in Hong Kong (over $100 cheaper). The kit looks wonderful, can't wait to get the build going.
What's the ETA on the aluminum chassis?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is online now   Reply With Quote
Old 01-25-2015, 01:37 AM   #251
NITTO550's Avatar
I'll tell you this, I had the same decision to make and I also chose the d07. Awesome car , it just works!
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 01-26-2015, 12:01 AM   #252
Still waiting for the "Dynamics" Edition...
Hope they will release due to this summer...
Gero is offline   Reply With Quote
Old 01-26-2015, 05:26 PM   #253
NITTO550's Avatar
I'm running the box setup with all the shocks one hole up,, with 3000 in the rear diff and I really would like the car to rotate faster. Any suggestions?
Rich D..
Old 01-27-2015, 02:08 AM   #254
Ryan Maker's Avatar
If you haven't cut the little 'knob' off the steering knuckles, I would suggest doing that first to give you more steering lock. After that you could look at shortening the front wheelbase to 1mm behind the front arm instead of the kit 3mm. You could also look at using a red front spring and a little more (8.5mm to centre of the pin) rear droop.
Hope this helps!
Ryan.
Old 01-27-2015, 01:21 PM   #255
You could also drop down on your diff oil weight try 1000 and see what happens.
