Old 01-16-2015, 08:17 AM   #226
cooliomojo-CEBU's Avatar
Default active rear suspension
Korey:
Hi! Seems like you have tons of experience with the car already. Have you tried it with the optional active rear suspension?
cooliomojo-CEBU is offline   Reply With Quote
Old 01-16-2015, 08:20 AM   #227
For those who have tried active rear suspension... is this beneficial for handling? Will it make the car faster? More drivable?
Old 01-16-2015, 10:58 PM   #228
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
It will be coming eventually, but I personally don't think it will be needed on 85% of tracks, The car is that good anyway
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-19-2015, 05:17 PM   #229
Default D07 Front belt wear and tear
Has anybody else had any issue/s with the front belt getting worn from making contact with the pinion (grub screw end)?
Out of the 4-5 people i personally know with D07 it appears I am the only one that has had this issue. I had my belt on same tension as most of these people mentioned.
Some of us have the same brand of pinion gear too. The grub screw itself was sticking out from the pinion in the slightest amount possible, so slight you would never think of it being an issue. When installed the pinion is around 3-4mm away from the belt. Problem for me now is that the worn belt caused some slipping and now the alloy pulley has wear on it.
When I put new belt on, I changed to a different brand pinion and although wear is now minimal i can still see some wear on it which i suspect is from the worn pulley now. Doh.
Just wondering if anyone else has had something like this happen to them and if its something i've done wrong.
69rotang is offline   Reply With Quote
Old 01-19-2015, 05:24 PM   #230
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Check your pulleys and spool incase they're caked with fuzz.
You could also try tightening the belts so there's less slack for them to wobble into the pinion.
It is a close fit on my mod car.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is online now   Reply With Quote
Old 01-22-2015, 04:00 PM   #231
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Anyone have a 17.5 high traction carpet setup they are willing to share?
Final decision between this and the Xray is coming in the next few hours. I'm leaning to the VBC for a few reasons:
1. It's not an XRay (everyone drives those)
2. Price is almost $100 cheaper (here in HK where I will pick it up)
3. Grey and red looks amazing.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is online now   Reply With Quote
Old 01-22-2015, 04:14 PM   #232
Fredp1's Avatar
My 12 year old son raced the D06(with D07 plastics) on the weekend in the IMCC CUP Australia and came 2nd in the 21.5 class. These cars are pretty good and the D07 is even better.
We normally race outdoors, but petitrc have carpet setups.
Fredp1 is offline   Reply With Quote
Old 01-22-2015, 06:00 PM   #233
Korey Harbke's Avatar
When I get home from the office I'll post one up. It's a good starting point.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-22-2015, 06:03 PM   #234
Thanks Korey.
Any of the factory guys planning on attending the Carpet Nats @ Horsham in March?
Old 01-22-2015, 08:20 PM   #235
Here ya go!
If you guys don't have yokomo springs handy, the kid orange/red actually work really good as well.
Old 01-22-2015, 08:33 PM   #236
Originally Posted by Korey Harbke View Post
Here ya go!
That's not the rear shock hole you told me!
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 01-22-2015, 08:34 PM   #237
It's always good to make sure you get the right hole
Old 01-22-2015, 08:45 PM   #238
R3VoLuTiOn's Avatar
This car, feels good in almost any hole from bottom to middle.
Old 01-22-2015, 09:50 PM   #239
Will this work with the D07?
http://vbcracingusa.com/store/alumin...ost?search=fan
Old 01-22-2015, 10:08 PM   #240
Whoooooops. That should be Hole #2 on the rear arm. Let the jokes fly in.....
