Old 12-24-2014, 04:36 PM   #166
Just got my d07 today and what a kit. Started building it and its a dream to build. Any little tips out there when. Building ??
______________________________
VBC D07 MUCHMORE FLETA PRO MUCHMORE FLETA 4.5
VBC D06 TEKIN RS PRO LRP 21.5
SPEKTRUM HITEC SAVOX
RAB HOBBIES
onroad racer is offline   Reply With Quote
Old 12-24-2014, 07:16 PM   #167
carkillaii's Avatar
Looking For a good starting set up for 17.5 carpet rubber tire.....
carkillaii is offline   Reply With Quote
Old 12-24-2014, 07:44 PM   #168
Les
Les's Avatar
Originally Posted by Korey Harbke View Post
I'm in the us in Washington State (WA). You might be mistaking me location for Western Australia
-Korey
Lol yes Korey we have a Redmond in WA close to where I live, it's a little country town lots dairy farmers, I didn't think there would be anyone living there with your knowledge of RC.
All the best.
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 12-24-2014, 07:49 PM   #169
patorz31's Avatar
Try the kit setup it is surprisingly good. I just tweaked it a little from there. 50wt front oil 40wt rear. I used a little less droop 1.5mm front and rear over ride height.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 12-25-2014, 01:19 AM   #170
Hannes's Avatar
Just finished building this awesome kit but I worry if I could use other spur gears than the ones from Panaracer. Kimbrough seems to be to wide to fit inbetween the pulleys...
Apart from this issue the assembly of this car went pretty well. When I came across the assembly of the stabilizers, one of the stabilizer ball cups split in four parts during screwing in the M3x3 screw. Anyone came across this too?
VBC Wildfire D09
www.rcmsc-greuthof.de
Hannes is offline   Reply With Quote
Old 12-26-2014, 02:17 PM   #171
Richards Racing's Avatar
RAB HOBBIES
Just watch out with the shockie piston check the groove sometimes a excess in material is in the groove. I had 1 in my build and make sure that is facing down.
Noel
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 12-27-2014, 07:10 PM   #172
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Is there a lot of difference from the 006 to 007?
Alan Hall
AlanHall is offline   Reply With Quote
Old 12-28-2014, 03:43 AM   #173
Korey's car is FAST. I'm sure driver had something to with it, but still... Got whupped by more than one d07 tonight.
-Mike
Old 12-28-2014, 05:24 AM   #174
NITTO550's Avatar
+1
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 12-28-2014, 05:26 AM   #175
NITTO550's Avatar
Also are you able to upgrade from the 6 to the 7 or is it not cost effective.
Rich D..
Old 12-28-2014, 05:43 AM   #176
NItrox416's Avatar
I don't have he d07, but I think to be quite well informed.
to upgrade totally the d06 you have to mantain only the diff bulkhead, ammo and screws
I have considered to upgrade only substansial parts so: main chassis, upperdeck and motor mount (including pulley), well only for these you need approx (here in europe but in hong kong it don't change) 80+20+50+40= 190euro approx
the plastic change only the material that is stiffer and the upper hole in the rear hub, the suspended steering(plus 40 euro), damper mount that, I think, have got only different shape e thickness
For me it isn't worth my money, I think it's better to sell the d06 and buy the d07.
NItrox416 is offline   Reply With Quote
Old 12-28-2014, 11:54 AM   #177
Korey Harbke's Avatar
There are a lot of new $$$ chassis parts that would need to be converted, let alone the new suspension materials.
The Chassis plate, top deck, center layshaft/pulley system, motor mount, and floating steering rack are all costly parts. I don't really see it as cost effective, but you can do it.
As far as I know, there weren't any plans to release a conversion set.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-28-2014, 07:54 PM   #178
AlanHall's Avatar
-Korey
The items listed the only difference?
Alan Hall
Old 12-28-2014, 09:06 PM   #179
-All suspension plastics are a more rigid material
-New geometry rear hub carriers
-New chassis plate
-New topdeck
-New 3 screw suspension mounts
-New steering rack with revised geometry
-New Upper bulkheads with slightly different camber link locations.
-New center layshaft design
-New swaybar mounting design, with shorter swaybars to accommodate the new mounts.
That's the list that I can think of. Ryan might be able to chime in on other differences if I missed any.
-Korey
Old 12-28-2014, 09:58 PM   #180
ZeroDown7169's Avatar
Trader Rating: 53 (100%+)
Will the arms for the d07 fit on the d06?
ZeroDown7169 is offline   Reply With Quote
