Old 09-15-2005, 03:23 AM   #1
Default soldering wires on a V2
Any tips? I had to resort to my largest iron that I normally use for cells! My usual 25 watt iron wouldnt touch it, I can only assume the brush holders are very efficient at condusting the heat away!!!
AEDave is offline   Reply With Quote
Old 09-15-2005, 03:48 AM   #2
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
The endbell sucks heat up so quick that you need to use an iron that has a large tip or is a pretty hot one.
Serpent,B-Fast Rc,Discount Rc Store,
92zero.com,Lunsford Racing, Xpert Rc,
Schelle Racing Innovations
1armed1 is offline   Reply With Quote
Old 09-15-2005, 10:41 AM   #3
Send a message via ICQ to rcnewb2004
Sand the surface first! There seems to be a "protective layer" almost... on that endbell, because it stops the copper from oxidizing. (I am unsure of this) but after I began sanding the endbell, I had much better luck with my wires actually sticking!
rcnewb2004 is offline   Reply With Quote
Soldering wires to Mamba Max superlapS15 Radio and Electronics 2 04-13-2008 04:17 AM
Soldering motor wires on mm esc aggieboy Radio and Electronics 6 03-04-2008 04:13 AM
AMB PT - New Wires? jsmax Electric Off-Road 1 04-06-2007 08:33 PM
Wires!!! Tpg racer Electric On-Road 19 06-18-2006 05:21 AM
Soldering ESC wires Michael Barch Electric On-Road 4 03-03-2006 11:45 AM
SEO by vBSEO 3.5.0
