Old 01-11-2016, 08:43 PM   #76
EDWARD2003's Avatar
You'll have to glue it down. I don't think the servo tape will hold. Shoe Goo works well.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 01-11-2016, 08:46 PM   #77
Trader Rating: 13 (93%+)
its 3m double sided tape that holds 20Kgs
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-11-2016, 09:02 PM   #78
so should i be using regular trim or sub trim ?
Originally Posted by EDWARD2003 View Post
Savox servos have an offset which is different to most servos.
Get the McPappy Savox servo case.
http://www.mcpappyracing.com/store/p...Case-Core.html
With your trim settings, are you using regular trim or subtrim?
When you have your trim with uneven values such as -40 to the right. That should sound off some alarm bells with your steering setup. As I pointed out this is obviously due to your servo. In the mean time, you can still use the servo, but the steering throw should be adjusted independently left and right. If you adjust it as a whole which you have been doing, then you're going to run into your problem you mentioned above.
Hope this helps.
Old 01-23-2016, 05:01 AM   #79
Hi guys what's the kit side snd centre
Spring ?
Old 01-23-2016, 06:44 AM   #80
dan_vector's Avatar
Trader Rating: 27 (100%+)
Spring ?
14lbs centre
18lbs front
4.5lbs side
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-23-2016, 06:47 AM   #81
racerx1920's Avatar
Trader Rating: 210 (100%+)
what is a good starting setup for the car on the new black CRC carpet
Desoto Racing / Serpent America / ProOne RC
Serpent 748WC / Serpent s120LTR / Serpent Project 4x
Dunn Graphics
1/8th Scale Racers of Toledo
https://www.facebook.com/DunnGraphics1
racerx1920 is offline   Reply With Quote
Old 01-23-2016, 07:02 AM   #82
dan_vector's Avatar
I run my car pretty much stock setup on relatively high traction carpet. The only changes are 450cst oil, 10k on the side dampers and 5lbs side springs. Rest is stock setup.
Old 01-23-2016, 11:13 AM   #83
On the black carpet, I am running stock side and center springs on the rear, 650 cst oil, 2 hole piston. Battery is forward about 6-6.5mm from the rear posts, 1-1.5mm rear droop, 15k oil in dampener tubes. CRC .50mm front springs, 4mm spacers above the steering knuckle, 3 deg upper arm mounts, long upper arms. CRC blue tires front and rear, or CRC spec front tires, blue rears. CRC blackart lola body. Had to add about 36g of lead to reach 730g min weight, this is a super light car! Car handles awesome.
Handy tip I figured out. Get a second shock mounting bracket and double up with the stock one. Stock 2.5mm screws are still long enough, just need a longer screw for the front shock mount ball. Less flex in the shock mount, more consistent handling, and less chance of breaking it in a hard crash.
Another tip, for the front ride height spaces. Take some extra 0.5mm spacers and apply one or two layers of thick clear tape to the spacers. I use Gorilla brand clear repair tape. Each layer adds about 0.15mm thickness. Now you can get between the standard 0.5mm steps, which is a big deal on carpet. I have one set of spacers with a single layer of tape for 0.65mm and one set with a layer on both sides, for 0.8mm.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 01-30-2016, 09:00 AM   #84
performula's Avatar
Basic
performula is offline   Reply With Quote
Old 01-30-2016, 08:12 PM   #85
performula's Avatar
Basic
Old 02-03-2016, 02:08 PM   #86
performula's Avatar
Will a standard size servo fit (I thought to balance weight) this car or any recommendations on a mini that bolt right up? I thought about the 9650, but I'm new to 1/12 and worried it might strip. I wanted to try Savox however I read it cannot be centered without gluing. Id like to use the chassis mounts without hassle.
Old 02-17-2016, 08:09 PM   #87
Dork Missile's Avatar
Originally Posted by Phoenix82 View Post
Hey guys, Is anyone running an aftermarket kit axle? if yes which one. I am still running my in factory one in mine. Car has been working great but still not 100% sure about the diff set-up/feel. It seems to work fine but feels gritty even if its on a fresh re-build/break in? I have felt other diffs and other are super smooth compared to mine. But still loving the car. Next big race Dec 11-13 in the great city of Minot ND
Nick K
i agree with you...i am always working on the diff to create something smoother. i'm considering the pro-one swap once i run out of standard off-set mounted tires. i find it difficult to launch from a dead stop...starts are terrible for me. my recent return to 1/12 could have alot to do with that though...
Team Associated/Reedy/Schelle Racing/Go Go Hobbies/Toy Car Creative
B6D/B6/B64D/TC7/RC10R5.2
Dork Missile is offline   Reply With Quote
Old 02-18-2016, 08:01 AM   #88
The stock diff rings are pretty rough, and not always very flat. I sent a bunch of the stock rings to Fred at B-Fast to be resurfaced. Much smoother now. One ring was so far off flat that he couldn't fix it, lol. I've also run notched CRC diff rings, also redone by B-Fast. And I use Serpent ceramic diff balls. Waiting for the spacer to be back in stock at Desoto so I can use the Serpent caged thrust bearing assembly that comes stock on the S100LTR.
Old 02-19-2016, 05:57 AM   #89
orcadigital's Avatar
Trader Rating: 61 (100%+)
Most recently in building the diff on my F110, I used the steel diff balls and the Hudy Diff Grease. Wet sanded the rings with 600 grit and brake cleaner. Walked around Snowbirds for an hour breaking it in by hand (holding one side and spur and turning the other, then the other side) chatting with folks. It was decent when i started, smooth when i put it in the car, and felt amazing after the first run and a re-adjustment.
Feels just as smooth as my BFast SRX4 diff with Serpent Diff Grease.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 10-26-2016, 08:25 AM   #90
Default Carbon axle
In the hunt for an after market axlw that will allow me to run the thrust bearing set up that came with the s120ltr.My kit has the metal axle and would like to know what every one is using.Irs has one part #2112 is this the one I need.Thanks a bunch.
X marksthespot is offline   Reply With Quote
