Old 03-07-2015, 12:12 PM   #46
spacendeman's Avatar
Send a message via MSN to spacendeman
now
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 03-23-2015, 05:45 PM   #47
Trader Rating: 29 (100%+)
Anyone have any feedback on these? I just got mine today, plan to get it assembled by the weekend. I'll post some pics when I do.
branover is offline   Reply With Quote
Old 03-24-2015, 04:03 PM   #48
Got mine built today. Went silky smooth. Looks like a solid car. Hoping to get out on the track this weekend
Old 03-24-2015, 10:23 PM   #49
looks nice Branover!
This car just won the stock class at the EC 12scale at Hudy Arena!
http://www.redrc.net/2015/03/hagberg...5-112th-euros/
Currently:
Old 03-30-2015, 10:09 AM   #50
~McSmooth~'s Avatar
Ran my LTR for the first time on Saturday. The car is really good.
My biggest impression is how well it holds a turn. Doesn't have any desire to "wander" off line while in a sweeper or large radius corner.
I'm using associated .020 front springs, and associated green side springs (you'll need the associated spring perches, too). Using the Prime/Hotbodies center shock (27.5 wt oil) with associated gold spring. Also ran the "long" upper front arms setting (hinge pin towards middle of car), with 1 deg of camber. 6-degree arm blocks. 0-degree kingpin insert.
The car feels quite "stuck", but not to the point where it's bogging the car down. I was running the Protoform AMR-12 body, and I've found with my previous car that the Strakka frees it up a bit, so I'll try that this weekend.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 04-02-2015, 10:43 AM   #51
~McSmooth~'s Avatar
Thought I'd share a pic of the new sled.
Old 04-03-2015, 12:21 AM   #52
dan_vector's Avatar
Trader Rating: 25 (100%+)
Looks great. Plenty of room for the electrics as well by the looks. Next car for me is the F110-SF2 then I'll be all over this!
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 04-03-2015, 05:16 AM   #53
bigcracing's Avatar
Trader Rating: 32 (100%+)
What is the weight ready to race?
bigcracing is offline   Reply With Quote
Old 04-03-2015, 05:20 AM   #54
looking good !
ahyiii is offline   Reply With Quote
Old 04-16-2015, 07:38 PM   #55
bigcracing's Avatar
I just purchased one and was wondering if anybody have setups for med to high grip track running stock?
Old 04-17-2015, 05:00 AM   #56
~McSmooth~'s Avatar
Front:
Assoc .020 springs (use just 1 kingpin shim with these springs)
1 deg camber
All caster shims in back
6 deg blocks
upper hingepin inward
Blue compound tire
Rear:
Assoc green springs (you'll need assoc pn 4640 spring retainers also)
springs outward
10k lube in tubes
Green compound tire
2mm pod droop
Chassis:
HB Cyclone/Team Prime center shock (using this shock, you'll need to cut the ball-cup as short as possible)
27.5 oil in shock
Assoc gold shock spring
1.5mm shims under rear shock mount (on the pod).
Bottom hole in front shock mount.
Battery transverse, all the way rearward
PF Strakka body
I would normally have all this in a setup sheet, but the one at the Serpent site doesn't work quite right.
Old 04-17-2015, 04:49 PM   #57
bigcracing's Avatar
Thanks I will give it a try thanks.
Thanks Chris
Old 04-20-2015, 07:42 AM   #58
~McSmooth~'s Avatar
If using the Hot Bodies/Team Prime center shock, get Serpent PNs 411333 (short shock mount) and 411206 (long ball cup).
Cut 1/16" off the ball cup. This will give you more range for the pod droop adjustment.
For mounting the shock cap to the front mount, I use an Associated ballstud (PN 31288) and a 3mm hex nut.
Old 09-13-2015, 09:39 AM   #59
Phoenix82's Avatar
hey guys . i have a question. the king pin is very stiff slidind thru the steering block. is this normal? this is my first 1/12 attempt.
nick k
Desoto Racing|Novak|Airtronics
Phoenix82 is offline   Reply With Quote
Old 09-14-2015, 09:53 AM   #60
Yes that's normal. The kingpin does not move through the steering block during normal suspension travel. The steering block and kingpin move together as one piece.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
