Old 10-07-2014, 11:10 PM   #1
Default Team Magic E4RS III
The Team Magic E4RS III will be released end of the year, probably in November.
Many things will change, it’s why it’s a new car (E4RS III) and not only a simple evolution of the E4RS II and E4RS II EVO.
The car has been created in collaboration with our drivers, mainly in France, Switzerland and Germany; it has been a real big job of the team, where anyone contributed to the project by sharing his idea and knowledge. The car also benefited of advices from external top drivers which also tested the car during training session; mainly in Germany.
The new elements:
  • New lower bulkheads, lightened and compact, with ball-raced anti-roll bar holders as we already have since 3 years in option, but this time directly on the bulkheads; and thinner belt tension adjustment possibilities.
  • New arm holders, attached to the chassis and no more on the bulkheads.
  • New upper bulkheads, with an optimized turnbuckle / roll centre position, and still one-piece for a better rigidity (one asset of the E4RS II and E4RS II EVO).
  • New shock towers, ultra-rigid and thick, to avoid micro-torsion during efforts.
  • New upper deck, higher placed for a better flex control, with a new flex point over the steering system.
  • New floating steering system, which don’t interfere in the flex movements; and new servo ballcup, more rigid for an increased precision.
  • New central battery guides, and optimisation of the battery position / fixation.
  • New ultra-smooth shock bodies (new mirror finish and Teflon coating).
  • New shock upper cap, for a rebound very close to 0.
  • New Teflon piston shaft guides.
  • New ultra-resistant belts, for powerful modified motors.
  • New lightened middle axle mounts, that also allow to use larger spur gears for modified motors.
  • New rear driveshafts, with G-clips instead of small grub screw (like the double articulated front ones).
  • New lightened and ultra-rigid servo mount
Elements that comes from the E4RS II and E4RS II EVO:
  • Hard plastic components for an optimum control of suspension movements.
  • Symmetric flex system, which is a key features of the car handling.
  • Front double articulated driveshafts, which gave us entire satisfaction.
  • EVO motor mount, which is the only support on the market that allow a lateral adjustment of the motor position.
  • Spool and gear differential, which are plenty satisfying.
Concerning the new arm holders:
This was something difficult to change; because the system of the E4RS II and E4RS II EVO was working fine, and gave us entire satisfaction in term of performance. It was simple, easy to adjust, and the small plastic holders was perfect in case of crash by preventing the axle to bend or the arms to break. This was a performing and functional system, so why to change it?
RC models isn’t just performance and reliability; it’s also beauty, changes, fashion and prejudices.
The E4RS II EVO with its “old school” arm mount screwed to the bulkheads wasn’t very sexy and provided an image of obsolete car; that not corresponds to current standards with arm mounts attached to the chassis.
But instead of “changing to change”, or more simply “changing to do like the others”, we searched a mean to keep the advantages of the EVO arm mounts with the extra fin lateral setting with shims; to avoid to require 88392743932 arm mounts that corresponds to all the toe angle and possible axle positions. So, we created new arm holders with very fine and precise setting inserts.
So, we keep the same lateral setting possibilities than on the E4RS II and E4RS II EVO, with the advantage to have the new finer setting possibilities for the axle’s height, as it’s now with shims (instead of the old -0.75 / 0 / +0.75 arm mounts).
The E4RS III features the finer lateral setting of the market, for a car with holders screwed directly to the chassis plate; and this, only with 3 different FF and RR mounts, and 2 RF and FR mounts.
More details and pictures will come mid-October.
OUR CAR ISN’T COMING SOON …
… BUT IT IS COMING FAST !!
www.teammagicrc.net / www.hrcdistribution.com
RC Infos is offline   Reply With Quote
Old 10-08-2014, 12:32 AM   #2
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Mmmmmm....
Brokin Racing is offline   Reply With Quote
Old 10-08-2014, 04:53 AM   #3
ThePanda's Avatar
Trader Rating: 64 (100%+)
Been a while team magic. Glad a new car is coming.
ThePanda is offline   Reply With Quote
Old 11-27-2014, 04:53 PM   #4
December is almost with us...
Old 11-27-2014, 04:56 PM   #5
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default pictures
pics? where is the eye candy....we want Candy
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-07-2015, 01:32 AM   #6
Hi all. Any update on when this new car will be available? Ran the Evo for a while and it was very quick.
Team_Krusty is offline   Reply With Quote
Old 04-07-2015, 03:10 AM   #7
Trader Rating: 55 (100%+)
http://www.teammagicrc.net/E4RS_III/
Jamison R is offline   Reply With Quote
Old 04-09-2015, 05:05 AM   #8
daveaustin5's Avatar
RC Mart have it in stock: http://www.rcmart.com/team-magic-e4r...g-p-59293.html
daveaustin5 is offline   Reply With Quote
Old 04-09-2015, 01:46 PM   #9
Very nice looking car.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 04-09-2015, 02:00 PM   #10
Wow great price too. Just need to see if they will stock spares. Had a few dramas getting spares for the Evo here in Australia.
Old 04-15-2015, 06:13 PM   #11
Default Build review
So even though I have no idea where I'm going to get spares from I decided to pull the trigger and buy one anyway
It's all assembled and ready for some track time so I thought I would share some of my experience with the build.
Firstly the build quality.... Superb! I really don't understand how other brands (insert your flavour here) can't get it as good for so much more money. Everything built really well with next to no slop with no unnecessary shimming. Part a connects to part b and part c and that's it - excellent fit and finish. None of the 'just a light sand here' or 'fix with blah blah o-ring'. Credit to them.
The inserts for toe/track/sweep etc are a great idea. No need to purchase suspension blocks for variations. I don't like the fact these sit on shims for roll centre adjustment though. Tamiya has shims that slide in for the FR and RF blocks that they used on the 419 that work well. Maybe this is something TM could also consider.
Areas for improvement... I was missing a .75mm shim and a ball stud thread wasn't cut properly. Not really a game changer but in the interest of full disclosure I'm telling the full story. There are also parts to stiffen the car (top deck to steering bridge bracket and post from top deck to motor mount. I'm not sure if they are meant to be part of the kit or not (they are shown in the instructions) however they were not in my kit. Personally I found the e4rs 2 worked better for me with the top deck fixed to the steering bridge so I was disappointed to not have that part in my kit to try.
I also had a few c-hubs break on the previous car. They are quite thin again (probably same part) so I expect to break them more regularly than I would like.
All in all this is a great kit, factor in the price from RC mart and it's a no brainer in my opinion. Point me to somewhere I can get spares and I'll be a happy owner.
Simon
Old 04-19-2015, 06:04 AM   #12
jags2012's Avatar
Nice car... but looks alot like the Evo II.. hard to improve on whats already good.
Everything MUST GO...
contact: jags@videotron.ca
jags2012 is offline   Reply With Quote
Old 04-19-2015, 10:02 AM   #13
Ivan Dickson's Avatar
Trader Rating: 10 (92%+)
Team Magic nitro program did pretty well, I'm curious to
how well there EP program will do...
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 05-05-2015, 02:29 AM   #14
Wheelnuts's Avatar
It seems with only one or two cars available to run in the ETS they are going very well with a top 10 in the previous meet and just outside that in the most recent round .
I've got one coming to build so i'm hoping it works well too
Wheelnuts is offline   Reply With Quote
Old 06-06-2015, 02:06 PM   #15
Another A-final at ETS
