977e
#106
Am using the tekin 2650 kv motor esc combo on 4S. Tried with 16T pinion today and it was awesome. Nearly equals the other on 6s with a hobby wing 2000 kv motor and the bonus is the 2s batteries are a third the price of the 3s ones.
Next test is with a 17t pinion.
#107
HI everyone
running a TEKIN RX8 Gen2 ESC , my Pekin engine broke down and would like to know your advice on a new engine ; I was using a 1900 kv , with 3S Lipo , Pinion 15T on a 977e and was pretty happy with the combo ...
Wondering if you have some other brands tested in this set-up
Thxs
Thxs
#109
I have 3 sets of 3S Lipos , would prefer keeper this investment alive by using 1800-1900kv range engine .... finally , I will go for a Speedpassion 1800kv to see ...
#111
6S all in
was using 1900kv Tekin engine and before the "issue" , was runnind really well
#113
#116
Finally found time to post here, not only FB
Racing with 977e is fun! Still need to do little work on setup (understeering) and more time on the tracks.
MORAC Graz this weekend:
Previous month in Cervignano Italy:
#117
Very nice! What motor and ESC do you use? Is 4S the normal battery configuration for your races? Are the other racers running the 977e or are they running other conversion?
#118
I use modified HW 150A Xerun and modified Trackstar 1900. I run 6S.
Here are the results: http://www.morac-graz.at/rennen/2015...F_Ranking.html
Buri racer: http://www.rctech.net/forum/nitro-ro...sic-class.html
4S running in MORAC for 7min with 977e could be very demanding on the motor. 6S runs much cooler.
#119
Hello
What could I start within regards to ride height ?
New contact tyres fitted
And droop perhaps ?
And droop perhaps ?
#120
Thanks miholc. Currently am using a 2000kv with TURNIGY trackstar ESC with 16T pinion. On 4s it is nippy but with 6s it is awesome. I am yet to experiment with 17 & 18T pinions due to poor weather.
I wanted to try a higher kv motor for my motonica RS3 which I only plan to run on 4s as the 3s batteries are so expensive. That's good to know about the Tekin as that was another option but they are crazy money!
This is a good thread, subscribed!
