Old 11-25-2014, 10:10 PM   #76
about 2590g with body and wheels mine is...i have titanium screws and ball joints.
just for a rough indication...im putting in about 2500 mah to recharge battery after the usual 5min race. we have a large track it was made for 1/8th.
Last edited by jeff_78; 11-27-2014 at 07:15 PM. Reason: correction to weight 2590g rtr
jeff_78 is offline   Reply With Quote
Old 11-26-2014, 05:10 PM   #77
fab888's Avatar
I am a Serpent guy since 20 years and quality is awesome
I run both Nitro and EP 1/8th and comparing them is not that easy ; you can be a GP car fan and love the EP ; i just bought my 977e and my lap time are similar to the 966TE ones ; honestly , I still presently prefer the nitro one even if I struggle with my clutch ...
and I already over discharged one LIPO ....
fab888 is offline   Reply With Quote
Old 11-27-2014, 12:28 AM   #78
M7H
M7H's Avatar
Originally Posted by NDZ View Post
Hi M7H, 21 laps is impressive stuff ;-)
Couldn't see the top speed on Mylaps practice though
14,6 fastest laptime is also pretty fast.
Anybody interested in a 966E
See you on the track.
Hi Niels! Long time no see!
Yes it is impressive isn't it!
To see top speeds go to the old practice website of mylaps.
http://practice.mylaps.com/practice/...ate=2014-10-26
Serpent
M7H is offline   Reply With Quote
Old 12-18-2014, 03:42 AM   #79
Originally Posted by jeff_78 View Post
ive used the IX8 a lot on 4s, it is really cool and its a little softer power, easy to drive consistent.
but at the moment im using a turnigy 150A genII with 6S.
I have the blaze motor too, (1800kv)...looks good....havnt run it yet. be sure to get the sensored version to run with iX8.
Out of curiosity Jeff what punch rate and timing settings are you finding work best with the GenII ?
Serpent 977
James73 is offline   Reply With Quote
Old 12-18-2014, 05:26 AM   #80
KRYS06's Avatar
@fab888, hi, i'm krys from france and i have a question about main chassis.
The main chassis is cut in part to fix allow bulkhead front and rear, have you re-cut a little holes in chassis to put bulkhead because on my chassis the bulkhead is not really in place in holes.
I ask to m.salven but no response about it.
You understand ? Because my english is bad
KRYS06 is offline   Reply With Quote
Old 12-18-2014, 08:16 AM   #81
I have 15 punch rate and no timing and i find that its better with taller gearing like 18T pinion.
im using 1800kv sensorless. It has had plenty of runs now having no troubles.....i removed fan from motor as i found it unecessary after getting a chance to run on a warm day. its always battery temps and voltage im more concerned with....but those are fine too! even the 4000mah turnigy packs.
and KRYS06 no sorry i personally havent had any trouble fitting the bulkheads to chassis plate..both front and rear??..i cant think of any problem areas....Id suggest providing a photo
Old 12-18-2014, 09:36 AM   #82
BIBOY's Avatar
Send a message via Yahoo to BIBOY
hi guys what is thickest battery that would fit the 977e standard is 25.1 have you guys tried thicker battery?
R1 Wurks
Serpent USA
Desoto Racing
Picco Engines
BIBOY is offline   Reply With Quote
Old 12-18-2014, 01:43 PM   #83
Cheers Jeff. I too am thinking of removing the motor fan as the my 2000kv motor has stayed cool after several back to back uses.
Serpent 977
Old 12-18-2014, 02:43 PM   #84
KRYS06's Avatar
jeff thanks for reply, m.salven ask me today and he say it's not normal, me and my friend ordered two chassis kit last week and he has the same problem, i think the last production has a problem.
I must broaden machining chassis plate before build it and i don't like this...
Old 12-19-2014, 04:08 AM   #85
That is how the recess that my front bulkheads slots into looks too. I have had no problem with it. Bulkhead screws in firmly with no alterations needed.
Serpent 977
Old 12-19-2014, 05:27 AM   #86
KRYS06's Avatar
On my frame it was lacking 1mm reamind front and rear.
I try to locked screw at maximum and the bulkhead not go inside chassis plate correctly.
Old 12-19-2014, 04:54 PM   #87
Hi. Don from Christchurch New Zealand
Just got my 977e and had first run last weekend
Wow what a machine. Raced with the gas cars, and was on the pace only 2sec behind
after 5 mins,
My car has a Hobbywing combo 2250 11.1v 14/48 pinion spur. Used 3000mah 0 timing
Have put a 17 pinion in for next run. Motor was 80deg. So will watch
Using the bigger batts as only ones I could get for good price 39mm thick, just removed the side batt holders and taped to car. Worked well. Would love to get the right size but hard to get and seen expensive
Don C is offline   Reply With Quote
Old 01-29-2015, 09:06 PM   #88
Default the Nosram Falcon 8 Brushless Speed-Control
I've come up with a major setup problem with my ESC,
the Nosram Falcon 8 Brushless Speed-Control & Fatboy 8 BL Motor (1600kV)to be used in my Serpent Viper 977e, the EP version 1/8th onroad car with 6S LiPo batteries.
I just follow and adjust what it says in the manual regarding the setups for over hundreds of times:
the connections are good,
the setup procedures are good,
and the mode programmings are good!
What surprised me most should be the fact that no matter which power profile I chose in MODE 3, the power feedbacks should be EXACTLY the same. That is to say, I have only one power profile in MODE 3. (* I have double-checked the stored values by couting the number of flashes of the blue SET-LED, and they have been proved to be stored accordingly with no doubt.)
So could anyone be kind to let me know if there should be anything wrong or anything should have been missing during th setups?
Looking forward to your quick response!
Thanx alot!
P.S.: the Nosram Falcon 8 Brushless Speed-Control is exactly the same version of LRP iX8, so if you should have the same issue with your LRP iX8, please share your threads BTW.
P.P.S.: I've emailed my question to Nosram for help weeks ago,and it seems that there's no customer service person available. This is the first and last time I try Nosram devices in my life.
KK0420 is offline   Reply With Quote
Old 01-29-2015, 10:32 PM   #89
I guess that 1600kV would be fairly mild and maybe wont notice the difference between power profiles?
Is the power delivery not to your liking? what are you trying to achieve by adjusting this?
Old 01-29-2015, 10:45 PM   #90
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Not sure if you guys know, there is a Swiss Company called PBR Concept that have a conversion kit to transform the 977 Viper (Nitro version!) into electric (and back again).
It lets you run the Tectrade electronics in the car
Check out the photos!
Just another option...
977e-977e_engine-mount_2.jpg   977e-977e_komplett.jpg   977e-977e_gear-holders.jpg   977e-977e_set-1.jpg
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
SEO by vBSEO 3.5.0
