Old 10-03-2014, 10:02 AM   #76
Bar
Originally Posted by CristianTabush View Post
I'd like to see a saddle pack car again. With the electronics set ups of today, the cars would balance very nicely with that set up.
+1
I have been thinking this for a while, quite a few 1/10th 4wd offroad cars utilise this layout
Luke Burr
Bar is offline   Reply With Quote
Old 10-03-2014, 10:22 AM   #77
Originally Posted by daleburr View Post
Maybe the Pro2 layout is being resurrected rather than the Pro4!
Isn't the sprint2 a resurrected pro2?
I guess it's technically a resurrected sport2.
2uzferunner03 is offline   Reply With Quote
Old 10-03-2014, 10:37 AM   #78
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Yeah, I think it's about time to give the concept a try again.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 10-03-2014, 10:41 AM   #79
theproffesor's Avatar
Trader Rating: 53 (100%+)
The sprint 2 is a pro 2
SMC - Motiv - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-03-2014, 10:47 AM   #80
If it's belt, the losi 22-4 layout comes to mind...
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 10-03-2014, 11:10 AM   #81
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by theproffesor View Post
Oh and update the internal ratio to something more appropriate for todays motors. Something closer to 2.0.
IMO one of the big flaws with the EVO6 is the 2.5 ratio. Guys having to get all crazy on pinion spure combos.
Evo4 gears fit...using both pinion and crown give 2.294. The pinion must be sanded down some to fit right.
Old 10-03-2014, 12:31 PM   #82
That may be true but spending more money on an already $600+ car to get it right shouldn't have to happen.
Old 10-03-2014, 12:43 PM   #83
Chaz955i's Avatar
Not everyone in the world runs 25.5 so settling on any gear ratio is a compromise for someone somewhere else in the world. I couldn't run the stock spur that came with my T4. Tough sh@t. I changed it and got over it.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-03-2014, 12:53 PM   #84
Changing out diffs is alot different then changing out a spur. Every other car made now has around 2.0 internal to include your T4.
Old 10-03-2014, 12:56 PM   #85
DesertRat's Avatar
I wonder if the car will be piston damper or some kind of Awesomatix-like rotary setup.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-03-2014, 01:02 PM   #86
wwddww34's Avatar
Trader Rating: 9 (91%+)
It will probably be a complete surprise. Maybe something like 4 Flex T-plates for each wheel and a continuous variable dampener system made out of Unobtainium.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 10-03-2014, 01:32 PM   #87
2.5 is fine, the Evo6 can fit small spurs and there is a lot of room to move the motor. My awesomatix had an I.R of 2.55 and that was fine.
As to the Pro5 a shaft drive Mi5 would be interesting.
Qatmix is offline   Reply With Quote
Old 10-03-2014, 02:29 PM   #88
peter george's Avatar
Trader Rating: 318 (100%+)
For some reason it sounds like HPI will focus on a couple of things that will be drastic and change the tc platform....at least their tc platform. Im pretty sure belts are not going away but that they are gonna focus more on motor and lipo positions. I bet its gonna be great.
Team Underdog-Team UPURZ-Island Raceway & Hobby-Showing up and paying entry fee alone is not:"supporting your track" Stop fooling yourselves-buying online kills local racing programs.If we trade lower feedback always ships first.Team Associated B5m-CRC-Durango DEX210-CSO-Intech-Eagles of Death Metal-Tylenol
peter george is offline   Reply With Quote
Old 10-03-2014, 02:45 PM   #89
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
So you're wanting to use saddle packs that have a higher internal resistance? Those are even being phased out in off road where IR isn't an issue.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 10-03-2014, 03:52 PM   #90
Im usually an out of the box thinker, but the only belt system that really makes any sense and to be a radical departure from todays TC's is a JRXS/JRXS-R set-up. The type - r only came to be because they used the rotation force of the motor to help produce more rear grip. But with brushless motors the motor in the middle would work great and with low pro-servos the norm in racing, space is a non-issue. Due to ROAR rules, the car will have to accept iether a full size lipo or a saddle. It cant be designed around a shorty or square pack. But it could be made to where that is the optimal battery. Short servo, motor, esc/rx, then shorty batt... all down the middle. A three belt design as in the 22-4 isnt likely as the more belts you have the less efficient the drive system.
