Old 12-23-2016, 03:44 PM   #841
motoj550's Avatar
Trader Rating: 21 (100%+)
Is this thread dead, nobody running these now, time to revive it, i just got me one of these and would like to get some starting setups for this, like shock oils and rear diff oil and shock springs. or just a good starting setup.
XR10 A Higher Plane Of Existence
motoj550 is offline   Reply With Quote
Old 12-25-2016, 03:09 PM   #842
Airwave's Avatar
I've assembled one some months ago, ran two packs, put it back in the box.
Shocks are crappy, I have to rebuild them after 2 packs. The best to do is to use the teflon inserts from the TCXX in the bottom of the shocks, it can make them more constant...
After that, that's always the same, you run indoor, go for pink-silver/silver-blue/green-pink... If you run outdoor, go for silver-silver. That's a good start point.
Airwave is offline   Reply With Quote
Old 01-13-2017, 04:22 PM   #843
motoj550's Avatar
Well i finally got it built, waiting on esc and motor to get here. need to order up some orange washers - the lower a-arms have too much play in them plus need some for tuning. got a hold of an older BNIP Moorespeed Andy Moore replica body, i just love that paint scheme!
Old 01-15-2017, 11:06 PM   #844
motoj550, what did you use to paint the edge of orange?
SoLost is offline   Reply With Quote
Old 01-16-2017, 07:07 AM   #845
motoj550's Avatar
I used a sharpie oil marker, you can get them at Michael's. i sealed the edge's 1st with CA glue then used the oil marker. I think it adds some touch to i, makes it look nice.
Old 01-19-2017, 05:12 PM   #846
motoj550's Avatar
Got a issue i think, would someone let me know whats wrong here, got this built and was trying to get ride height set but the only way i can get it set is with about 2mm to 3mm of play in the shock spring when you lift the tires off the board, set it back down and ride height is 5.5 rear and 5 front, but when you pick it back up the springs get loose. is this normal or do i have something wrong somewhere. this is my 1st on road car. i do a lot of offroad racing and have never had this kind of problem in any of my cars. any help would be much appreciated.
Old 01-19-2017, 05:37 PM   #847
SpidarX's Avatar
You need to set droop using the set screws in the arms. You have too much drrop which is allowing the arms to fall down too far and thus making your springs loose. You only need about 1 to 2 mm of droop.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 01-19-2017, 05:47 PM   #848
motoj550's Avatar
I've got the droop set as per instructions to 8mm front and 9mm rear with car setting flat on board and measuring from board to center of chub hinge pin. most of the team drivers setup sheets use this same measurement. i'm at a loss here.
Old 01-31-2017, 03:12 PM   #849
Guys I have a brand spanking new built Pro 5 I am looking to sell. Never has touched the ground. I hate to let it go but I have too many other projects going on. Please pm me if interested.
theVetteman3 is offline   Reply With Quote
Old 02-02-2017, 04:00 PM   #850
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
Is anyone still racing this chassis in 17.5 or 21.5 usgt? I'm looking to pick one up and try it out. I want to compare this chassis to my destiny car!
racer034life is offline   Reply With Quote
Old 03-06-2017, 11:04 AM   #851
kewdawg's Avatar
Can you please tell me What's the part number on the TCXX Teflon inserts and who makes those springs?
kewdawg is offline   Reply With Quote
Old 03-29-2017, 02:32 PM   #852
ATOMIC's Avatar
I just put up my Pro5 for sale if anybody is interested. Perfect condition, lots of extras.
Mint HPI Hot Bodies Pro5 Pro 5 with lots of extras
ATOMIC is offline   Reply With Quote
Old 06-27-2017, 10:27 AM   #853
ShaunMac's Avatar
Looking for a spool with outdrives compatible with blades. Anyone use another brand with success?
ShaunMac is offline   Reply With Quote
Old 06-27-2017, 10:37 AM   #854
kewdawg's Avatar
Are you problems with the stock unit?
Old 06-27-2017, 12:55 PM   #855
ShaunMac's Avatar
No. Would just prefer to use blades to help outdrives and driveshafts last longer.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
GuyIsDamGood
