Old 01-20-2016, 02:54 PM   #706
tc3 racer sc's Avatar
Originally Posted by Hi-LowBlow View Post
Good job Craig at the race!!
hiro when can we have c hubs I got a car built and no hubs what the deal if I go to the birds I have not parts I guess it sit till then or run my tcxx
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 01-21-2016, 09:49 AM   #707
Hi
The c hubs are already available and in stock at HPI USA. But it seems hobbico which is our main distributor in the North American market still doesn't have those in the system yet.
I will try to check with our sales and will let you know as soon as possible. Worst case, we will try to see if we can provide you the parts directly for the Birds. We will see.
Thank you for all your support.
Hi-LowBlow is offline   Reply With Quote
Old 01-27-2016, 09:46 AM   #708
Maxxican's Avatar
Trader Rating: 65 (100%+)
reminder you CAN use the TCXX C-Hubs with a little shimming they work great i have been running them for the last few months. I club raced with Hiro this weekend and i think i saw them in his personal car also.
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 01-28-2016, 06:49 AM   #709
What droop are you guys using on the pro 5? I've seen quite a few setups posted on petitrc and many are using around 9mm front 8mm back. Compared to the other cars which I've, they're only running 5mm front 4mm back. Thanks.
N15M0 is offline   Reply With Quote
Old 01-28-2016, 06:57 AM   #710
scoyle's Avatar
The setup sheets quoting 9mm and 8mm are measured with the car sitting flat on the setup board and then the 9mm is measured from the board to the point on the hub hinge pin using a ruler or calipers.
Most other cars are quoted around 5mm with the car on 10mm blocks and a stepped droop gauge.
I am still using the kit 9mm and 8mm indoors on carpet...
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 01-28-2016, 07:01 AM   #711
Those droop # are based off of the center of the c-hub pin on the arms.
I run 5.2 front & 4.5 rear @ 5.5mm ride height. Using Hudy gauges.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 01-28-2016, 09:56 AM   #712
Thanks for the clarification.
Old 01-28-2016, 08:25 PM   #713
CraigM's Avatar
Trader Rating: 34 (100%+)
Don't forget to run the 5mm hex (or 4.5mm hex with 0.5mm wheel spacer) to maintain correct track width when using the TCXX hubs
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-29-2016, 08:05 PM   #714
Hi
well I got the car at the birds no rep from hpi can't run the car cause no c hubs what the hold up
Old 01-31-2016, 11:40 AM   #715
here is a video from my second outing with the pro5. the car feels pretty good. just needs a few more tweaks. i found out after the races though that my left chub was broken and moving around a lot. fortunately, most of the turns were right turns
https://youtu.be/p7QAxanJ__8
DOTMAN is offline   Reply With Quote
Old 02-01-2016, 02:40 PM   #716
Maxxican's Avatar
Time for a fresh kit.
i have a Pro5 for sale here.
HB Pro5 TC
Carlos F.
RoadRunnersRC.com
Old 02-07-2016, 04:38 PM   #717
Scooty's Avatar
Angry
First off ill start by saying I do enjoy my pro5 and I do expect to break parts, that's not the issue. But what is a huge issue is not being able to get new parts. Is April 30th a realistic date for all these steering parts coming back to being in stock?! State champs are in March so how can i expect to run this car?
Scooty is offline   Reply With Quote
Old 02-07-2016, 04:54 PM   #718
Scooty's Avatar
Does anyone know if there are any steering blocks from different makes that will fit the TCXX C-hub? without having to get a longer drive shaft or any other mods. Thanks!
Old 02-07-2016, 04:56 PM   #719
I would say that's probably pretty accurate. HPI (at least North America) has been horrible about releasing and stocking parts for the better part of a decade now.
wareagle84 is offline   Reply With Quote
Old 02-07-2016, 09:45 PM   #720
CraigM's Avatar
I doubt it, most other cars run an extra 1mm spacing in the axle. What's the issue with the std steering blocks? I haven't had any issue with them
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
theVetteman3
