Old 10-11-2015, 02:49 PM   #616
Trader Rating: 30 (97%+)
I have a carbon bumper support and carbon battery stoppers both nib make an offer located in Canada thanks
zaraz is offline   Reply With Quote
Old 10-22-2015, 10:25 PM   #617
CraigM's Avatar
Trader Rating: 34 (100%+)
Default Soft option c-hubs
http://www.redrc.net/2015/10/hpi-pro...oft-c-hub-set/
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-23-2015, 05:05 AM   #618
Originally Posted by CraigM View Post
Where can you buy those hubs? My usual source (WHEELSPIN) doesn't have them listed, nor does RCMart. And when I Google the P/N I only get HPI web site references.
Also I was looking at the PRO5 parts list on WHEELSPIN. They show the Big Bore Shocks but refer to them as the "regular length". Are the PRO 5 shocks the same shock length as the TCXX upgrade kit came with the short Big Bore shocks?
John Wallace2 is offline   Reply With Quote
Old 10-25-2015, 05:06 AM   #619
CraigM's Avatar
The shocks are ~63mm long. Not short shocks
Old 10-25-2015, 11:23 AM   #620
PRO 5 has especially gd performance in MID or LOW traction.
Eric_Choi is offline   Reply With Quote
Old 10-31-2015, 09:31 AM   #621
tc3 racer sc's Avatar
I can't wait to get my car together
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 11-01-2015, 01:59 AM   #622
CraigM's Avatar
Only good things to report after my first run today
Old 11-02-2015, 05:34 AM   #623
dizzy1's Avatar
Trader Rating: 24 (100%+)
Yeah you will love this car, especially on low to med bite tracks. Its planted with lots of low, mid and high speed steering. Box setup is near perfect for those tracks. Only time had issue was on high bite, car is so stuck that making changes to free it up, just some rear toe changes and comes alive there as well.
Just remember that rear toe is slightly off. So 3.0 block is about 3.3-3.4 toe. Using the 2.5 block gets it to about 2.9ish. Don't quote me on the exact but this was from Hiro. I always run the 2.5 block in the rear now.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 11-06-2015, 02:05 PM   #624
dizzy1's Avatar
Please tell me your joking about a 2016. I hoped HB would not go down the route like everybody else with a new version each year.
Old 11-06-2015, 02:28 PM   #625
hope not, maybe an upgrade but not a new car
Rc909 is offline   Reply With Quote
Old 11-08-2015, 12:03 AM   #626
Update = Groskamp input
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 11-08-2015, 05:24 AM   #627
[QUOTE=John Wallace2;14234885]Where can you buy those hubs? My usual source (WHEELSPIN) doesn't have them listed, nor does RCMart. And when I Google the P/N I only get HPI web site references.
QUOTE]
Still waiting on a source of supply for those C hubs? Anyone!!!!
Old 11-09-2015, 10:39 AM   #628
Maxxican's Avatar
Trader Rating: 65 (100%+)
Pro5 Infantry Tip:
if you like your shocks to be buttery smooth use the new yellow O-rings #114673
These o-rings make the shocks very smooth and don't swell as much as the standard kit o-rings and don't need to be replaced as often.
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 11-09-2015, 01:33 PM   #629
dizzy1's Avatar
Wallace-Tower has them listed as late December for the new C hubs. Are people still having issues with the stock C hubs? I'm still using the same ones from the kit and no issues still. For other option parts, i see tower has most listed as on order or late Dec. I'm waiting for the split .5 blocks. Ordered others from Europe but waiting for those.
Old 11-09-2015, 07:34 PM   #630
CraigM's Avatar
The TCXX hubs are also worth a try. You need a shim to take the play out at the outer hinge pin but they seem to make the car smoother
