Old 06-18-2015, 12:38 AM   #526
Texco's Avatar
Thanks Reyns!
Texco is offline   Reply With Quote
Old 06-22-2015, 07:45 PM   #527
Hi Guys, I've just finished building my PRO5 and have noticed a lot of play in my steering, looks like its coming from the bell cranks, there is a lot of up and down movement from it not sitting tight up against the crew. Has anyone else experienced this? any solutions? i cant find a shim thats the right size
jonston is offline   Reply With Quote
Old 06-22-2015, 08:02 PM   #528
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
That was my only complaint too.
The post is a bit too tall. I filed them down till there was less play.
It's better, but not perfect. Doesn't seem to hurt anything
Chrisgt2 is offline   Reply With Quote
Old 06-22-2015, 09:01 PM   #529
dizzy1's Avatar
Trader Rating: 24 (100%+)
Did you get your pro5 in US? If so where?
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 06-23-2015, 03:25 AM   #530
RC MARKET's Avatar
Kit & Parts instock
RC MARKET is offline   Reply With Quote
Old 06-24-2015, 10:08 PM   #531
Thanks, its very poor I think. everything else is spot on. I aligned it last night on my Hudy station and I cant get it to align properly with the mount of play its got, incorrect readings up to 2 degrees
not happy HPI. I wonder what Andy Moore is doing on his car. surely cant be driving it like that.
p.s you just filed it down? hand file?
Old 06-24-2015, 10:50 PM   #532
dizzy1's Avatar
Is the play only in posts being too tall or something in bearings/rack/ball ends sloppy as well?
Old 06-25-2015, 01:39 AM   #533
yeah just the posts. everything else is good.
the whole bellcrank can move up and down .5mm, amplify that with the whole steering system and its massive.
Old 06-25-2015, 04:14 PM   #534
Are the axle spacers that go between the pin the bearing right size, that could take up some of the slack.
John Wallace2 is offline   Reply With Quote
Old 06-26-2015, 07:43 AM   #535
Trader Rating: 31 (100%+)
What is the ID of the steering post bearing? I imagine you can find a shim set with .1, .2, .3 mm shims in it with the correct diameter.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 06-27-2015, 10:01 AM   #536
dizzy1's Avatar
For anyone that has a pro5 and some old purple arm mounts, can you compare if same measurements? Looks like the same other than the pro5 mounts have an alignment pin that goes into the chassis. Wondering if old purple mounts still work on new car.
Old 06-27-2015, 10:12 AM   #537
Chrisgt2's Avatar
They do not fit, bolt pattern is wider.
However the split inner mounts do fit.
Old 06-28-2015, 12:20 PM   #538
dizzy1's Avatar
Cool, thanks Chris
Old 06-29-2015, 10:13 AM   #539
The split blocks at the rear from TCXX fit but need an extra 0.5mm shim as screw centres to face of block is shorter. We have also run the TCXX option solid blocks for the front/rear instead of the split blocks if we want to reduce chassis flex these again fit fine but need a small adjustment to shimming.
Unfortunately the front/front and rear/rear blocks from TCXX do not fit.
Jason
jasonb is offline   Reply With Quote
Old 06-29-2015, 01:42 PM   #540
dizzy1's Avatar
Thanks Jason. Now if the kits would only hit the states already!
