Old 10-07-2014, 03:39 AM   #136
RC MARKET's Avatar
Japan news is a belts car !
RC MARKET is offline   Reply With Quote
Old 10-07-2014, 04:01 AM   #137
theproffesor's Avatar
Trader Rating: 45 (100%+)
Well i guess they expect to sell kits by the 10's. Hope they can keep up parts support for that many.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-07-2014, 08:07 AM   #138
SpidarX's Avatar
I for one am glad it might be a belt car. Never been a fan of shafts. I've never seen a shaft car run as quiet as a belt car. I don't understand this desire for a shaft car.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 10-07-2014, 08:55 AM   #139
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
because its different - and would be cool to have a top contender produce one that might be able to hang with the top belt cars...
other then that - I dunno...
I'd rather see a known working configuration improved rather then re-inventing the wheel
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-07-2014, 09:01 AM   #140
Send a message via ICQ to JiuHaWong
More "punch" coming onto the throttle, especially coming out of turns. My only concern is parts, HPI/HB does not have a good track record recently, IME.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 10-07-2014, 09:13 AM   #141
You dont need "low friction" belts with a shaft drive. Its called bearings... its always low friction
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 10-07-2014, 09:37 AM   #142
The only parts the belt touches are the pulleys which is where the friction is. Don't shaft cars have input gears? There's your friction.
2uzferunner03 is offline   Reply With Quote
Old 10-07-2014, 10:02 AM   #143
There is a massive amount of surface area that belts contact the pully, at least 50% of the circumfrance. Ring and pinion have maybe 1/10 the contact area of a belt system. Also there is no tension to have to set and get wrong. Too tight and create drag on the system and strain the motor. Too loose and you waste power on slack in the system and loose some braking ability.
Of course belts have a good system right now, they have had top priority in R&D for almost a decade until the Awesomatix.
Then there is the "if its not broke dont fix it" argument. That argument is just plain lazy. If that were the case we would all still be running the same design of chassis from 15 years ago.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 10-07-2014, 10:07 AM   #144
I'm impressed with how eager people are to here about the car, and find it curious its not being called the new tcxx. The emphasis on the Pro, being the fifth instalment to me is more exciting as I think a lot of us ran the old RS4 Pro and Pro 2 (and still do)
Any idea if Andy Moore will be running the new chassis this weekend at the worlds?
TLR 22-4, HPI RS4 Pro, Sanwa MT-4S
VikingBen is offline   Reply With Quote
Old 10-07-2014, 10:35 AM   #145
As far as the tension on belts go the same can be said for the ring and pinion. Too tight of a gear mesh and your putting strain on the system. Too loose and your tearing the teeth up.
I'm going to assume that r&d get a lot of their ideas from the pro drivers their company use who are actually out their testing the stuff. So if they want belts then I want belts too.
It would be interesting if they made two cars. One belt and one shaft to please everyone. I remember when the pro3 was out Hara had a specially made shaft version he used for some practices but always went back to the belt for mains.
Old 10-07-2014, 10:40 AM   #146
SpidarX's Avatar
In the case of light crashes, does a belt system not help to absorb some of the impact being transferred to the spur and pinion (due to some slack in the belts)? Whereas with a shaft drive, you increase the chance of stripping gears in a crash?
Maclan Racing
Old 10-07-2014, 11:02 AM   #147
wwddww34's Avatar
Trader Rating: 9 (91%+)
+1
I remember stripping dozens of conical gears in my Pro 4. Specially when I put the spool in the front of the car.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 10-07-2014, 11:30 AM   #148
The keyword is here is stability, and high power + shaft does not get you that compared to belt.
In terms of surface area, belts actually achieve less friction than belt at higher speeds. The shaft excels at low speed acceleration thus the success of the A700 in stock classes.
They both have their pros/cons, but it really depends on what HPI/HB is trying to appease: stock or mod?
redbones is offline   Reply With Quote
Old 10-07-2014, 11:32 AM   #149
2uzferunner03; I remember when the pro3 was out Hara had a specially made shaft version he used for some practices but always went back to the belt for mains.
Actually that prototype probably ended up being the pro4. That's when I got out of rc so I'm not sure.
Old 10-07-2014, 11:34 AM   #150
The pro4 had notoriously easy to strip gears. Didn't need a hard crash to strip them. I wouldn't use the pro4 as an example of shaft drivetrain durability. Take a look a the awesomatix gears, I doubt you could strip the ring and pinion on that car.
malkiy is offline   Reply With Quote
SEO by vBSEO 3.5.0
