Old 09-17-2014, 05:59 AM   #1
dave-man's Avatar
Default Carpet Subfloor Question
We're putting in new carpet with a subfloor. The old stuff was just glued down to the concrete. My question is, what should we use for the subfloor? I've heard of 2 layers of 1/2" OSB. I was also told to use 3/4" MDF. (2x4's laid face down 16" on center)
Does anyone have any suggestions one way or the other? We're obviously trying to work within a budget but we want it done right the first time.
dave-man is offline   Reply With Quote
Old 09-17-2014, 07:10 AM   #2
Email scotty Ernest. His temporary track for the IIC is awesome
Juan Aveytia is offline   Reply With Quote
Old 09-17-2014, 07:32 AM   #3
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The 5280 guys just renovated their track
Loads of info & drama HERE
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-17-2014, 07:36 AM   #4
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Here's a link to the pics of the subfloor we put down at NORCAR at the Gate:
https://www.facebook.com/#!/20379807...type=3&theater
We used plastic, 2x4"s, then 2 layers of 7/16" OSB, then lots of sanding
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 09-17-2014, 09:02 AM   #5
dave-man's Avatar
Wow!
Old 09-17-2014, 10:16 AM   #6
Thumbs up
Originally Posted by dave-man View Post
Wow!
Those guys are pefectionistas, and that track is pretty bitchen
Old 09-17-2014, 10:58 AM   #7
Smoothest straightaway EVER....
The NORCAR guys did an awesome job.
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 09-17-2014, 12:41 PM   #8
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
3/4 tounge and groove. 2x4 16 on center. perfectly flat, 5 years down now.
Molzermoweryracing
http://youtu.be/XNw949zzVb4
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 09-17-2014, 01:21 PM   #9
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
2x6 I-joists w/3/4" tongue and groove OSB, 16" OC. Build the perimeter so the floor is completely elevated by 2". Shim every 10 feet up the joist to keep it level. The joists can be just about any length and when done with this spacing there is no bounce and you can build it laser flat. If permanent, use liquid nails to hold the top down. Predrill all screw holes and sand lightly after anchoring.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-17-2014, 01:36 PM   #10
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Here was ours when we built it 3 years ago. 3/4 tongue and groove 30year Advantec floor under layment. 2x6's, cracks and low spots after leveling were bondod up and sanded smooth. Our floor was horrible so we had to use lag bolts to level the floor due to a 4" difference from one end to the other. Came out perfect.
EA
Carpet Subfloor Question-photo-1-1-.jpg   Carpet Subfloor Question-photo-2-1-.jpg   Carpet Subfloor Question-photo-3-1-.jpg   Carpet Subfloor Question-photo-4-1-.jpg   Carpet Subfloor Question-photo-5-1-.jpg
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 09-17-2014, 09:39 PM   #11
syndr0me's Avatar
Trader Rating: 32 (100%+)
Wow!
Nicest, most successful track in the country. We're passionate about what we do. Perhaps too passionate at times.
syndr0me is offline   Reply With Quote
Old 09-17-2014, 10:13 PM   #12
bkspeedo's Avatar
I would recommend 2 layers of non tongue and groove OSB 3/4" with alternating pattern from first layer to second so all joints overlap by 4ft. Screwed together with about 40-50 screws per sheet. If there's any major high or low spots glue and shim.
Not all OSB sheets will be the same thickness so check when placing. Thinner sheets will need to be placed on outer edges were cars normally don't drive. At 5280 we didn't think about this issue so we had some spots that needed sanding. We rented a large floor sander for this job.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-24-2014, 02:11 PM   #13
theproffesor's Avatar
Trader Rating: 55 (100%+)
I do construction part time with my father who has been doing it for 45 years. Never have I ever laid joist on the long edge. They will bow and flex more in that direction. Why would you lay them down like this verses the standard of vertical? 2x4 or 2x6 should be more than enough support with 3/4" tongue and grove osb. Use a strong adhesive between the joist and osb, then screw, not nail, the osb to the joist. Screws are overkill, but it will hold them down better. Finally get a floor sander to smooth everything out.
Of course that is all after you have set a level for the top of the joist. I look at like building a deck. Set some 4x4 or 6x6 post if you just feel the need to over do it, 6" tall every 8 feet and set the top of the joist level just above that to give some wiggle room for uneven concrete. When the structure is finished it will be so heavy, it wont go anywhere. Everyone seems to be making this way too hard IMO.
I also don't understand the need for two layers of ply wood. We aren't parking real cars on it. All I could see that doing is creating more places for the floor to separate and create high spots. If the first layer isn't level them the second will be worse
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is online now   Reply With Quote
Old 10-24-2014, 02:20 PM   #14
Have you looked closely at some of your fellow R/C racers over the past few years?
Serzoni is offline   Reply With Quote
Old 10-24-2014, 02:41 PM   #15
Very true. Gotta love good ol' MERICA' home of the whopper.
