Old 01-14-2016, 03:43 AM   #61
Regional Moderator
CarbonJoe's Avatar
Originally Posted by sbd View Post
I will measure and let you know. I am still on my first inserts after many crashes. When the ball studs get lose I put a drop of middle CA and screw them gently. After the glue cures you can tighten them even more than on new inserts. Works for me this way already an year now.
Or just use a 3mm button head screw from the bottom.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-14-2016, 03:53 AM   #62
sbd
The head of the button screw may be hitting the battery especially at the rear...
On my X1 it is ok as I use an 1s format battery and there is more than enough clearance.
sbd is offline   Reply With Quote
Old 01-14-2016, 06:12 AM   #63
pphaneuf's Avatar
A problem with that is that the hole is much bigger, and in a funny shape, to fit that plastic insert. So the head of the screw wouldn't have much to hold on to...
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 01-14-2016, 06:40 AM   #64
sbd
I guess he means screwing the bolt into the plastic insert from below. This is applicable to X1 as the shock is mounted on balls and then grubscrew but the X10 shock is mounted on ball studs. Hence the only option is CA...
Old 01-14-2016, 07:26 AM   #65
pphaneuf's Avatar
I could trim the insert so that it kept the screw centered, but it might be a bit weak, I'll see...
My favourite option would really be to replace the plate with the X1'16 and forget all about this, if the holes are in the right place?
Old 01-14-2016, 07:52 AM   #66
sbd
Once I get to my shop I will measure, but keep in mind that even if the holes are OK, you may not be able to use the X1 16 part as its hole is drilled for countersink bolt, so it will not work easily with the X10 ball stud...
Old 01-14-2016, 07:54 AM   #67
pphaneuf's Avatar
Argh, yes, you're right, because it's a touring car shock.
Xray, hurry up with that X10'16!
Old 01-15-2016, 02:52 PM   #68
Car Breaker's Avatar
It is here and nothing too exciting other than price. Still no floating servo mount. Maybe I should customized my own chassis
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 01-28-2017, 08:15 PM   #69
Customworksking's Avatar
Trader Rating: 73 (100%+)
ugh
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-29-2017, 05:44 AM   #70
pphaneuf's Avatar
Originally Posted by Customworksking View Post
ugh
Something's come up? I'm just about to make a transplant, putting the pod bulkheads of my X12'16 into my X10'16...
Old 01-30-2017, 06:21 PM   #71
what body is best
Old 01-30-2017, 07:41 PM   #72
pphaneuf's Avatar
what body is best
I rather like the MIX-RC 78224:
http://www.mix-rc.de/default.asp?ex=...82&kat_id=1027
Old 01-30-2017, 07:49 PM   #73
sorry for WORLD GT-R
