I cant get my screw off
take a dremel and cut a slot into it and use a flathead to get it out
nope. Take a 3mm drill and drill in the head until it falls off. Then, take a pair of pliers and unscrew what's left of the screw. Advantage : you won't make any slot in your chassis / parts. Inconvenient : none.
if u dont wana dremel the chasis, take a drill with a bit the size of the head and start drillin into the head and when u can c carbon fiber take all the screws out of the upper deck xcept that one and carefully pull up on the uper deck, head will pop of and and just take out the rest of the screw with your thumb
Originally Posted by warpig
The title of this thread is hilarious! haha
First i would ask what type of allen wrench are you using>> a standard l shaped one, or a nice torker style. the l shaped on do not fit as good, and it can seem like a screw is stripped.. I have seen guys come iton the shop i use to work at with the stripped screw.. i used my torker allen wrench, it fit tighter and came right out..
also if you are going to drill out the screw, be very carefull.. the screw will hest up. it can damage the plasic part it is in by melting it.. i have also seen damage done to grafite from the heat.. if you do drill it out, use some bearing oil, or shock oil to keep the screw cool while drilling..
Originally Posted by rays_tt
telling me to drill
It looks like it is into Aluminum. You can also try adding heat. Grab a hair dryer or a heat gun, add heat and then try to remove the screw.
Snowy.
Snowy.
