Old 09-08-2005, 04:40 AM   #16
raving-monkey's Avatar
Send a message via MSN to raving-monkey
look like caphead screws to me...simply grab it with a pair of pliers (and using brute force ) twist it out.
when i am trying to get countersunk screws out, i drill a 2mm (.078" to you imperial guys ) hole all the way down the screw, get a stud extractor (like a screw but with opposite threads on) so when you tighten the stud extractor, it loosens the screw ..works every time and no messy chassis
also, what car is it
raving-monkey is offline   Reply With Quote
Old 09-08-2005, 06:22 AM   #17
Birky's Avatar
I think it is a Tamiya TB-Evolution 2.
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 09-08-2005, 03:49 PM   #18
rays_tt's Avatar
Trader Rating: 26 (100%+)
thanks guys i'll give it a try and let u know.
btw what makes what i say so funny?
rays_tt is offline   Reply With Quote
Old 09-08-2005, 04:56 PM   #19
Trader Rating: 36 (100%+)
I keep a couple left hand threaded drill bits in my box, just big enough to barely fit into the holes on the screws I use. They're the same as drill bits but, cut counter-clockwise instead of clockwise.
Put the bit in the drill, set it to go counter-clockwise, and carefully drill into the screw. Typically a couple turns into the screw, the bit catches it right and the screw comes right out.
I've done this probably eight times and it has worked perfectly every time.
That said, from that picture, it looks like the dremel and flat tip screw driver will work fine.
EVILGRAFX is offline   Reply With Quote
screw kit for BJ4 WE ??? trebor Electric Off-Road 4 02-20-2007 06:20 PM
Which set screw???? SPO Rookie Zone 5 05-15-2006 10:00 AM
WTB T3 SCREW SET coolguy5 R/C Items: Wanted to Buy 1 08-24-2005 09:14 AM
Oh man did i screw up primusblowsgoat Chat Lounge 56 05-10-2005 01:23 PM
Screw This!!! Darkman Australian Racing 41 04-17-2003 09:24 PM
SEO by vBSEO 3.5.0
