team powers actinium 17.5 question
anyone here experience a weird like cogging noise when set the timing to '0' or (-)? But when i set my timing to (+) no weird noise. is that normal?
Orca speedo. vx
This really only happens at very minimal throttle inputs like when lining up on the grid. At any normal throttle inputs, there is no cogging. My R1 Wurks motors were the same way. It's pretty much a non-issue.
I'm experiencing a similar problem but during a practice session last night it turned into a slightly bigger problem. In some cases, I have to push my car to get it going due to the cogging issue. I am going to try a new sensor wire and hope that the problem goes away. I'm using the HW V3.1 1S ESC in blinky mode, timing on the can is set at 1 notch before full timing, and my rollout is 94mm.
Less timing, more roll will make life easier
