Old 11-26-2014, 08:38 PM   #31
ByteStream's Avatar
Originally Posted by CristianTabush View Post
This is as far as I was able to go with timing today. The car ran very strong and I was able to match some of the fastest laps I have done. I will try the settings on the esc as well. Thanks for the report John.
Please also note that this is with a re aligned and re gapped sensor board to get it closer to the rotor. Some soldering is involved.
Can you share your process for re-alignment and re-gapping.? What you did exactly and what gap measurement you found to be best?
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-27-2014, 12:48 AM   #32
Thumbs up
Originally Posted by oeoeo327 View Post
I'd check to make sure that the bearings are seated properly in the can and endbell. If they are seated as they should be, you should have a small amount of free play with no shims installed. Once you've confirmed that the rotor "floats" between the bearings, you will most likely notice a difference in performance.
Spot on about the bearings, one wouldn't seat square and was binding on the rotor, stopping it from floating. They gave me a new end plate/bearing and it's all fine, test it out tomorrow. Thanks for your help.
SLIPPERY76 is offline   Reply With Quote
Old 05-19-2015, 02:27 PM   #33
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I am curious, what size of rotor comes with the motor? Is it a 12.3 or a 12.5? Thanks in advance!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-19-2015, 02:35 PM   #34
Super Moderator
Kraig's Avatar
I should have added, I looked at the website and it says 12.3 but there is a disagreement elsewhere so I would like your confirmation.
Old 05-19-2015, 02:35 PM   #35
Trader Rating: 18 (100%+)
Actinium = 12.5mm rotor.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-19-2015, 02:36 PM   #36
I have asked repeatedly to have that fixed. The webmaster tells me he fixes it then it pops back in again.
