Old 08-20-2014, 05:26 PM   #1
Default ddrive shaft help
do the 3 piece driveshaft's or d-joint drive shafts really help
i was thinking of buying some for my zero. would it be a worth while upgrade?
any info /thoughts would be great
TeamThibault is offline   Reply With Quote
Old 08-20-2014, 06:07 PM   #2
ShaunMac's Avatar
If you're trying to race competitively, get 'em!
They are a big improvement over standard driveshafts. You WILL feel the difference on the track. Smoother, more predictable cornering. I wouldn't race a car without them.
ShaunMac is offline   Reply With Quote
Old 08-20-2014, 06:10 PM   #3
ThePanda's Avatar
Trader Rating: 62 (100%+)
They help steering with a spool or on a car with higher steering angles. They are not necessary though, but they do help.
If you plan to use a drift car, you can get a higher angle off of standard cvds usually.
ThePanda is offline   Reply With Quote
SEO by vBSEO 3.5.0
