Like Tree11Likes
Old 01-10-2016, 02:11 PM   #121
vlad_sa's Avatar
Originally Posted by fyrstormer View Post
Are there any FWD classes? Or do they just make you run with the 4WD cars?
No there aren't any in Europe, sadly.
Tamiya TRF 419X / Tamiya TB EVO 5 Exotek v1 / Tamiya TB EVO 5 Raceberry Edition / Tamiya TB EXO 6 / Tamiya TB EXO 5 Raceberry Edition / Tamiya TA05 v2 Exotek / Tamiya FF04 EVO / Tamiya FF04 EVO Black Edition / Tamiya FF03 EVO / Spice Yokomo BD7 FF / VBC FF17 / Sabre FD Mini
vlad_sa is offline   Reply With Quote
Old 01-23-2016, 09:08 PM   #122
vlad_sa's Avatar
Short video of my black edition FF.
Amazing how much grip this thing has!
http://youtu.be/2-rUsQcJYs0
Old 01-24-2016, 05:59 AM   #123
bmxcrx's Avatar
You can run FWD in the USGT class. FWD minimum weight is 1200 grams while the 4WD guys have to be at a minimum of 1450 grams.
I run a FF03R in this class at 1300 grams race weight. It's a mid pack car. I've been tempted to buy a FF04 to get to that 1200g minimum but I went with an EXO 6 instead.
Current cars: TA07 / FF04 |
For Sale (thread coming soon):
M05v2 / FF03R / Exotek TB04 / F104v2 / F1R3 / RC10R5
RC Car World - Willingboro, NJ.
bmxcrx is offline   Reply With Quote
Old 01-24-2016, 08:30 PM   #124
fyrstormer's Avatar
[YOUTUBE]http://youtu.be/2-rUsQcJYs0[/YOUTUBE]
Is that carpet? What kind of tires are you using? All I have to drive on is pavement, and I never got acceleration anywhere near that good -- too much wheelspin. That's why I built a FWD XV-01 with part-time 4WD instead.
fyrstormer is offline   Reply With Quote
Old 01-24-2016, 08:35 PM   #125
vlad_sa's Avatar
Carpet indeed. I use primarily Sorex 28R on the FF.
What oil your running in your FF? I'm using 300k and seems to be working fine. Also I'm running stabilizers front and rear. They are a must on FF
Old 01-24-2016, 08:41 PM   #126
patorz31's Avatar
I am running 2.5 million in the front of my FF.
patorz31 is offline   Reply With Quote
Old 01-24-2016, 09:06 PM   #127
vlad_sa's Avatar
What also helped a lot is to adjust the ESC to the car.
Punch level to 1, so car is not as aggressive coming out of the corner, that reduced the wheel spin massivly for me.
Also PKW is set to mid/high range, so before you go full throttle car already has built the mechanical grip.
Also play with different springs. I'm running kit springs here which are actually meant for asphalt but they work quiet good on carpet too.
Old 01-25-2016, 04:29 AM   #128
fyrstormer's Avatar
I don't have the FF04 anymore, I took it apart and used it to upgrade an XV-01. However, for reference these are the setups I'm using:
XV-01 4WD: 30k front, 10k rear
XV-01 RR w/ 4-wheel braking: 1k front, 30k rear
XV-01 FWD w/ part-time 4WD: 30k front, 2k rear
XV-01 FF: TA-06 rear spool in the front, nothing in the rear
I suppose I could use the bottle of 1M oil in the front diff on the XV-01 FF, or maybe the super-sticky OFNA diff-lock putty (which is about 500k, but has some kind of adhesive additive that makes it feel like glue), but a spool was easier and requires no maintenance.
I agree the rear swaybar is a necessity. The front swaybar, I dunno. I wouldn't use a front swaybar unless you're actually getting too much oversteer with only the rear swaybar, because the front swaybar will lift the inside front tire when accelerating out of a corner and allow wheelspin.
Old 01-25-2016, 04:36 AM   #129
fyrstormer's Avatar
PKW?
Old 01-25-2016, 07:15 AM   #130
vlad_sa's Avatar
PKW?
Drive frequency, but I'm pretty sure it's labeled as PKW on the Program Card.
Old 01-25-2016, 07:23 AM   #131
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
I don't see the video,,the link didn't work
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-25-2016, 07:30 AM   #132
patorz31's Avatar
here I fixed it for him.
+ YouTube Video
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
Old 01-25-2016, 11:42 AM   #133
OVA
OVA's Avatar
+ YouTube Video
Old 01-25-2016, 01:46 PM   #134
fyrstormer's Avatar
I'm afraid I still don't know what that is, and I Googled "pkw drive frequency" and came up with nothing.
Old 01-25-2016, 01:48 PM   #135
vlad_sa's Avatar
Which ESC you're using?
