Tamiya TRF419
#1082
is it good?
http://www.liverc.com/news/new_produ..._IFMAR_Worlds/
42285 1/10 R/C TRF419 Chassis Kit
Availability: December
- Inherits the TRF418 suspension parts design, which has proven to be the new standard in Tamiya high-end R/C racing machines.
- Aside from the suspension parts, the rest of the chassis has largely been overhauled, including a new layout.
- Features newly-designed bulkheads, motor mount, dampers and gear differential unit.
#1085
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Thanks for the pics and link!
Curious, I noticed on that servo horn, the ball isn't right in the middle of the horn, it's offset a little to the inside much like my Evo6 said it should be but I don't understand why you'd do this on a 418/419 because unlike the Evo6, the other side of the link connecting to the steering bellcranks isn't offset as well.
#1087
Actually, if your using the kit servo saver, try mounting the link in the inner outer hole. It will make the length of the horn longer, and you'll need to crank the horn over... But it should provide a better resolution to the steering (20mm horn length seems to be most popular ATM)
#1088
Hey guys,
Two questions:
1. What makes the difference if wheelbase is longer by pivot block (B-B to C-C) or making it wider by spacer (1mm). Of course rest remain unchanged (toe is adjusted)
Other words: is it better to have wider/narrower wheel from pivot block or use spacer independently changing pivot block takes more time. I am interested driving carasteric change.
2. I have experienced - on mid grip carpet - wider front by 2mm vs rear makes car more stable, however on asphalt wider rear is better. Do you have similar exp? I tried 188mm vs 186mm
Marton
Two questions:
Marton
#1089
http://www.teamtrf.com/index.php/201...gory/39-trf419
If anyone would like a clean blank set up sheet along with Marc's Round 2 ETS set up.
#1091
You really need to stick to one brand and work off relatives.
Personally I use muchmore. It's clean silicone based for a start - others that are mineral based are like motor oil and make a mess (TRF/Xgear)
#1092
They are all over the shop. All of them. Some even say "CST" and some say "CTS" (centistroke is the word the acronym is supposed to stand for) and then many just say "WT" for weight which is just a label.
Just to have a decent selection, tonight I'm going order muchmore perfect diff oils 1000 to 3000. I believe it is available in increments of 500.
I did notice that MR33 brand has weight ranges in smaller increments, but whether or not I would notice such a difference is questionable.
Thanks for your feedback!
#1093
2000,3000,4000,5000 would have 99% of your bases covered when starting to play. You could book end with 1000 and 6/7000 if you really wanted to. I wouldn't bother with "half" weights in the muchmore stuff personally.
#1094
#1095
