Like Tree3Likes
Old 01-26-2015, 06:42 PM   #886
FWIW - I wasn't attacking the use of a ball diff, I genuinely wanted to hear why.
When the absolute majority are using a spool up front or perhaps a really heavy gear diff I was curious to hear the reasoning.
Turns out it was completely arbitrary
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 01-26-2015, 11:49 PM   #887
Originally Posted by fuse01 View Post
whats the parts number for one way for trf 418? i think 17.5 one way should drive better
I used the TRF416 one in my 418, I assume it will be the same in the 419 (I haven't used it in the 419 yet)
Indeed, needs must sometimes I just wanted to also stand up for the mighty ball diff, my 417 ones are still as smooth as butter (although they are not massively used).
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-27-2015, 12:42 AM   #888
I'm using a 417 one too and when I built it (and tightened it very hard) it was smooth as new. After a few runs tho it seems a little gritty but very consistent at least.
With the ball diff up front I felt I had way too much steering especially on corner entry. Which made the car difficult at the beginning because it would turn in so suddenly. Hence my chose of going back to a spool. I'll see what happens !
MatJ is offline   Reply With Quote
Old 01-27-2015, 02:23 AM   #889
Skiddins's Avatar
Originally Posted by Raman View Post
I personally still prefer ball diffs. complaints were they get dirty, discs were worn out, balls flat spotted.
Now we have gear diffs and 90% leak. Then we have to select different weight fluids.
So In the end, were still constantly rebuilding diffs lol.
I predict ball diffs will be back in the near future. One manufacturer will come up with some gimmick update to them and we will be suckered into hopping on the band wagon again.
With the exception of our lipo/brushless tech, I think gear diffs are the best development in recent years
No more inconsistency during runs, no rebuilding and never getting it quite the same etc.
The gear diffs only leak if they're crap or built incorrectly. I bought a few gear diffs, some new and some second hand, each with a different oil in it. So no rebuilding necessary, almost ever
I also run 1/12 and have to rebuild the diffs for that a lot... and I hate it
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-27-2015, 05:36 AM   #890
+1 on the consistency. Ball diff, unless you make them too tight, they'll loosen during the run.
Biggest issue with ball diff is diff slip imo.
Old 01-28-2015, 02:38 AM   #891
Simmi's Avatar
Hi Guys
Again and again problems with the 2.6 mm screw from the Drive Pulley. Already at my TRF 418, I had problems with the screws, I had to completely replace all motor mount and Drive Shaft ...
With luck and patience I was able to remove the screw.
Must get steel screws to have no longer problems
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 01-28-2015, 02:43 AM   #892
Salkin's Avatar
Originally Posted by Simmi View Post
Hi Guys
Had the same problem on the 418. Bought a bunch of the original screws and replaced with a new every time I needed to replace the spur or for maintenance. Never tightened too much.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 01-28-2015, 03:04 AM   #893
I striped a titanium one the other day. Painful.
But was easy to undo via the lay shaft with the kit spanner.
Old 01-28-2015, 03:53 AM   #894
niznai's Avatar
Hi Guys
The kit screw is steel.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-28-2015, 06:31 AM   #895
jedi's Avatar
Quick question guys. Is the 417 gear diff a drop in fit for the 419 and vice versa? Just want to know as I have a few spare 417 gear diffs. Thanks.
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
jedi is offline   Reply With Quote
Old 01-28-2015, 07:04 AM   #896
There only should be a little torque on that screw ...
if your bearings are free and correct that will not spin loose.
you guys are over tighten them....
Gordie
Gordie88 is offline   Reply With Quote
Old 01-28-2015, 07:33 AM   #897
I'm using a TRF419 geardiff in my TRF418 so i guess it shouldn't be a problem to use the TRF417 geardiff in your TRF419.
addicted2blue is offline   Reply With Quote
Old 01-28-2015, 07:45 AM   #898
niznai's Avatar
You'll probably need the narrow diff bearing holders/belt tensioners (TA05 type).
Team Greasy Weasel
Old 01-28-2015, 08:48 AM   #899
Simmi's Avatar
Since I had the Raceberry Conversation Kit for my TRF 417 V5, I hated the screws in the Drive Pulley and never attracted more than necessary, because I made already there my negative experience.
I had even then problems with the 2.6 mm screws, hoping for an improved system as the Smokem V7 set.
Can anyone recommend me a good screw, which can be turn out without any problems?
Team Yokomo YZ2 CA
Old 01-28-2015, 09:34 AM   #900
tentative 2mm 419 lower deck from Tamiya and what is that small piece next to it?
they kill hotlinks. scroll down.
torg is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
