Like Tree1Likes
Old 01-25-2015, 08:30 PM   #871
TryHard's Avatar
Originally Posted by Dan View Post
I'd hate for new people in the hobby to ask niznai for help at the track. He'll help you....then follow up with an insult. LOL
He'd help, but only tell you half the story, and then blame you when your not psychic and/or his bull gets found out...
Old 01-25-2015, 08:51 PM   #872
niznai's Avatar
Yeah, you forgot to mention I would charge for assistance, Mr Tryhard.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-25-2015, 08:56 PM   #873
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Hey everyone, you got me out of bed so knock it off and drop the attitudes!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-25-2015, 11:30 PM   #874
You know the answer to your signature is to use italics?
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 01-25-2015, 11:53 PM   #875
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
edit
Dan is offline   Reply With Quote
Old 01-26-2015, 02:53 AM   #876
Is it possible to get un-even tyre wear left right when you run a a track (clock wise or counter clockwise?)
I had new tires for Sunday and we ran clockwise and the left hand side seemed to have worn down a tiny bit more than the right. Especially at the front. Camber and all were equal after checking multiple time.
Could the fact I was running a ball diff up front impact the wear seeing that it allowed both wheel to spin at different rates ?
Thanks!
MatJ is offline   Reply With Quote
Old 01-26-2015, 03:20 AM   #877
You ran a ball diff - why?
Old 01-26-2015, 03:29 AM   #878
Because I didn't have a gear difd yet and I fancied to give it a go haha. It was extremely tight, but have replaced it with a spool now.
Old 01-26-2015, 03:49 AM   #879
It is possible, if for example, you have long right-hand sweepers at the end of straights. Those layouts definitely wear the Front-Left tires faster.
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 01-26-2015, 04:28 AM   #880
Right thank you! That was exactly the case, there was a right hand sweeper leading onto the main straight followed by a long right hand sweeper at the end.
Who uses tyre warmers on carpet ?
Without them, the car lacked grip and was sliding a bit. With the warmers, I could hear the tires screach a bit and push the car harder.
Old 01-26-2015, 05:05 AM   #881
My youngest girl (10 years old) runs her TA05 with 2 ball diffs with great results and i'm using a one-way in my TRF418 chassis
So far i have the fastest laptime at my club, i used to run a spool up front but switched to a one-way and improved my laptime with 0.3s.
I'm running a muchmore Fleta euro Blinky ESC and a muchmore 10.5T motor with 0 of timing (motor timing isn't allowed at the belgian nationals)
The second fastest guy is 0.2s slower then me and he's using the same ESC/motor combo as me and his car is a yokomo BD7 wich is mostly considered as a faster car then a TRF418.
Just saying that sometimes a ball diff or a one-way can improve your laptimes
addicted2blue is offline   Reply With Quote
Old 01-26-2015, 07:10 AM   #882
I also use a one way sometimes in 17.5 blinky. Works a charm as I hardly brake but I get better turn in on the infield and also the same power out of the corner as the spool runners.
It does fit a specific way of driving though, you have to be smooth on the brakes.
416/7 one ways are cheap to pick up as well
I also occasionally use a ball diff in the rear. I allows me to tune the car easily, especially if its at a track that I haven't raced on before. Once the car feels good in practice with the ball diff I can then feel the resistance and use a similar oil in the gear diff to match it.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-26-2015, 04:25 PM   #883
Raman's Avatar
Trader Rating: 49 (100%+)
I personally still prefer ball diffs. complaints were they get dirty, discs were worn out, balls flat spotted.
Now we have gear diffs and 90% leak. Then we have to select different weight fluids.
So In the end, were still constantly rebuilding diffs lol.
I predict ball diffs will be back in the near future. One manufacturer will come up with some gimmick update to them and we will be suckered into hopping on the band wagon again.
Raman is offline   Reply With Quote
Old 01-26-2015, 04:28 PM   #884
Raman's Avatar
Originally Posted by Simmi View Post
I learned a lot from Groskamps Tips and also helps everyone
https://www.youtube.com/watch?v=zAPI...pioffK2v-pJrJQ
@ 1,56 listen about the shiming
Love these clips by him. I reviewed his shock build tips right before building my 419
Old 01-26-2015, 05:30 PM   #885
whats the parts number for one way for trf 418? i think 17.5 one way should drive better
fuse01 is offline   Reply With Quote
