Like Tree7Likes
Old 01-21-2015, 01:54 AM   #811
Stein Tumert's Avatar
Originally Posted by EDWARD2003 View Post
I can't see the setup sheet, so I don't know. But, I would start looking at reducing static camber or camber gain.
If you go to Patrick's FB page, you will see it.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-21-2015, 04:25 AM   #812
EDWARD2003's Avatar
Originally Posted by Simmi View Post
Here: https://www.facebook.com/tamiyaracing.dk?fref=photo
Today I will done my new Protoform LW Dodge Dart. Tonight I run on carpet again with my BD7 Setup
Works now. He's running 0.5 under each block! This will increase the camber gain which is causing your grip issue (too planted). I would remove the 0.5 both front and rear. The front link heights look decent. The rear outer link shims should be dropped down to 1 mm, 4 mm is a little excessive.
Front camber - 1.5
Rear camber is good
Toe out .5 or 1
EDWARD2003 is offline   Reply With Quote
Old 01-21-2015, 07:38 AM   #813
CW22's Avatar
Trader Rating: 93 (100%+)
Originally Posted by cplus View Post
move the sticker then
its just a sticker right? R1rurks don't make an ECU yet do they?
No, that's the authentic R1 esc.
Not in the market yet.
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 01-21-2015, 07:47 AM   #814
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Works now. He's running 0.5 under each block! This will increase the camber gain<--I don't believe that is correct )which is causing your grip issue (too planted). I would remove the 0.5 both front and rear. The front link heights look decent. The rear outer link shims should be dropped down to 1 mm, 4 mm is a little excessive.
Front camber - 1.5
Rear camber is good
Toe out .5 or 1
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-21-2015, 08:16 AM   #815
BIBOY's Avatar
Send a message via Yahoo to BIBOY
that is an R1 esc soon to be at you local hobby shop
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
BIBOY is offline   Reply With Quote
Old 01-21-2015, 08:25 AM   #816
BIBOY's Avatar
Any reason for the ESC orientation. Looks more awkward than it could be if you rotated it 90deg clockwise?
i did not want to twist the wires the esc has similar config as the Orca the motor wire output is reversed .... i really wanted to show the R1 logo on the side
R1 Wurks
Xray
RC America
Reds Racing Engines
Rctarget
Old 01-21-2015, 11:59 AM   #817
maxepower's Avatar
Talking
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-21-2015, 03:26 PM   #818
EDWARD2003's Avatar
Originally Posted by RedBullFiXX View Post
Oops, I forgot to write 0.5 mm also raises the roll centre. Normally you use the camber link to adjust camber gain. Shimming the blocks has more effect on roll centre than camber gain.
Old 01-21-2015, 10:10 PM   #819
Raman's Avatar
Trader Rating: 51 (100%+)
Mine arrived today and I started the build this evening. All smiles so far.. Always a pleasure building a Tamiya, specially a TRF.
Just out of curiosity, does anyone know, what's the weight of the clear silicone fluid, that the manual recommends for the differential?
Raman is offline   Reply With Quote
Old 01-21-2015, 10:31 PM   #820
RC Passion's Avatar
Man! I wish I could drop coin on a 419! You're not giving up on the TB04 are you?
VBC
RC Passion is offline   Reply With Quote
Old 01-21-2015, 10:40 PM   #821
Trader Rating: 31 (100%+)
Tamiya usually includes 900wt for the diff.
ittjv is offline   Reply With Quote
Old 01-21-2015, 10:50 PM   #822
Simmi's Avatar
Here are some Pics about the HOT RACE in Italy:
https://www.facebook.com/Hotracetyre.../photos_stream
And here also my final Setup for Carpet
Tamiya TRF419-10940612_775936642473368_5663504386373752602_n.jpg   Tamiya TRF419-simmi_carpet.jpg
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 01-22-2015, 02:38 AM   #823
C van der Hagen's Avatar
#900
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 01-22-2015, 10:14 AM   #824
blf
Are there "better", metal diff gears that would be advisable to replace the GV/51567 tree?
Why does my EVO 6 have metal gears and a plastic/static cross pin and the exact opposite on the 419....plastic gears with alum/keyed (x2) cross pins?
blf is offline   Reply With Quote
Old 01-22-2015, 11:49 AM   #825
Marcika's Avatar
hey,
Does anybody know rc arena in Warsaw, Poland? Or where there is possibility to practice either on carpet or asphalt.
Thanks,
Marton
Marcika is offline   Reply With Quote
