Old 01-19-2015, 05:54 AM   #781
Simmi's Avatar
Originally Posted by BIBOY View Post
Building my 419
Did you guys have this issue the arms were a little tight and the suspension arms were no falling on their on weight ... Couple of things I noticed the shims provided were not exactly the correct thickness they were off (thicker) by as much as .07 to .03
My solution was I got a 1000 grit to take off material and 2000 grit sand paper to polish the shims and finally got to the correct thickness the arms are now free falling by its own weight
Use instead a 0,5 Shim (Kit) a 0,3 Shim and you have a free falling arm.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 01-19-2015, 08:42 AM   #782
Sandpaper is great. Jeweler Rouge is better. I use Metal gloss from Master Formula...
bertrandsv87 is offline   Reply With Quote
Old 01-19-2015, 01:43 PM   #783
It can vary arm to arm though. Don't be obsessed with having the same number of shims at all four corners. Making them slop free and free falling is the primary aim. A 0,05mm or 0,1mm difference arm to arm is fine. If you are getting larger differences than that, reset the blocks - loosen screws (1/4turn) and tap the arms etc.
cplus is offline   Reply With Quote
Old 01-19-2015, 02:09 PM   #784
Simmi's Avatar
I learned a lot from Groskamps Tips and also helps everyone
https://www.youtube.com/watch?v=zAPI...pioffK2v-pJrJQ
@ 1,56 listen about the shiming
Team Yokomo YZ2 CA
Old 01-19-2015, 05:34 PM   #785
Raman's Avatar
Trader Rating: 48 (100%+)
Originally Posted by cplus View Post
the Blue are Aluminium.
direct from Hiro Seiko. they should be arriving at local dealers now.
Thanks. I don't know of any dealers in the states.
My car is sitting at customs in Los Angeles should have it Wednesday
Raman is offline   Reply With Quote
Old 01-19-2015, 06:25 PM   #786
EDWARD2003's Avatar
I'm not hating, but the TRF419 wasn't looking so hot at the Hot Race this past weekend. I'm not sure as to why Marc R. is having such difficulties with the handling of the car. The car should be dialed in by now or at the very least a podium contender.
EDWARD2003 is offline   Reply With Quote
Old 01-19-2015, 08:35 PM   #787
Raman's Avatar
All good things come to an end.. Maybe it's time for MR to move on. Maybe that's why Tamiya hired NM
Old 01-19-2015, 09:42 PM   #788
PitBox Hobbies 4703 Sunset Ave
Indianapolis, IN 46208 United States
TEL/ +1-317-753-2516
www.pitboxhobbies.com
pitboxhobbies@live.com
Fordham Hobbies 2446 Creston ave
Bronx NY 10468
TEL/ 718-562-1906
www.fordhamhobbies.com
FordhamHobbies@aol.com
Old 01-19-2015, 10:19 PM   #789
:yup:!
Old 01-19-2015, 11:23 PM   #790
Simmi's Avatar
@Edward
I have no information about the race, not even on MR Facebook page.
Can not believe that the 419 will not run properly in Marc hands? Setup maybe steal from Völker
Any Link?
Team Yokomo YZ2 CA
Old 01-19-2015, 11:41 PM   #791
EDWARD2003's Avatar
http://www.myrcm.ch/myrcm/report/en/18861/143957
Click on "Fianls" then "A-main" 1, 2, 3.
Old 01-19-2015, 11:49 PM   #792
Stein Tumert's Avatar
@Edward
Any Link?
http://events.redrc.net/
Scroll down a bit for the touring cars...
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-20-2015, 02:45 AM   #793
Possibly hiding from such a poor performance
That's the DHI cup???
Old 01-20-2015, 05:22 AM   #794
Simmi's Avatar
@Edward, thanks
Viktor Wilck better than his Team Mate Marc M33 Rheinard?
Please Marc, use the Setup from a Yokomo and your Car always fly over the Race Way
Team Yokomo YZ2 CA
Old 01-20-2015, 06:45 AM   #795
@Edward, thanks
Marc posted his progress. The car did well but he had some issues in the races, he had a couple of collisions which drastically affected his pace (Busted a wheel in one race)
Patrick Folman did really well in his 419 and got into the A finals and managed 8th. Interested to see how the rest of the season develops.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
