Old 01-09-2015, 05:01 AM   #706
Here you go.
All the springs, 42278 at the front. Kit 418 incl. "bonus" to the rear.
And then each side by side - you can already tell they are grossly different. 42278 (with tubes for yellow and red) to the left.
And some numbers.
Yellow "hard" - 6 coils and 6.5 coils
Black "medium" - 6.5 and 7.25
Red "soft" - 7 and 7.75
All wire is 1.5mm and wound the same direction. For comparison, HPI silver (6543) are 6.5 coils of 1.5mm wire. So in theory same as the medium in the TRF set.
The 419 manual lists the springs as 42278 (red) so when I finally open my kit I'll compare those too.
cplus is offline   Reply With Quote
Old 01-09-2015, 05:21 AM   #707
And why not, a HPI comparison for Nerdiness sake.
TRF Black - HPI Silver - 418 Yellow
All 6.5 coils of 1.5mm. HPI wound the other way as compared to Tamiya.
And top view you can see how similar they are.
Old 01-09-2015, 05:25 AM   #708
Thanks for that. So my list will be for the kit springs not the pack ones. I need to check the ones in the 419 as I didn't even look at them.
Qatmix is offline   Reply With Quote
Old 01-09-2015, 05:33 AM   #709
I've never used any of these. I bought the TRF ones about the time I got the 418 thinking it would make a set as I mentioned. Unpacked them and thought "what the hell" and proceeded to use the ride springs I have and have just stuck with them - they are consistent and publish the rates.
I doubt I'll use the 419 ones either!
Old 01-09-2015, 09:55 AM   #710
lets get some Lbs compared to yoko pink and blues lol
Gordie
Gordie88 is offline   Reply With Quote
Old 01-09-2015, 10:59 AM   #711
SoCalMitch's Avatar
Here is a website that calculates spring rates.
http://www.thespringstore.com/spring...alculator.html
SoCalMitch is offline   Reply With Quote
Old 01-09-2015, 11:26 AM   #712
HMMMM THATS COOL
Gordie
Old 01-09-2015, 11:54 AM   #713
Trader Rating: 31 (100%+)
Nice! Thanks for sharing. Good to know they are different then. I always felt the 418 springs were completely worthless. Glad Tamiya recognized that. Maybe I'll pick up a set to try.
- JV
ittjv is offline   Reply With Quote
Old 01-09-2015, 12:15 PM   #714
What do you use for material?
Wouldn't that be different from one manufacturer to another?
torg is offline   Reply With Quote
Old 01-09-2015, 01:58 PM   #715
sgp-chris's Avatar
Hi guys,
I'm thinking about getting the 419, but is it possible to change the diff screws to something that fits and isn't a "self tapper" ? Is it even adviseable?
Just saw MR in practice today at the DHI Cup, car looked good, but not as fast as Volker and the BD7... I hope he can close the gap to Ronald during the weekend
Hotbodies D812 | Schumacher Mi5
sgp-chris is offline   Reply With Quote
Old 01-09-2015, 02:36 PM   #716
The diff case screws are fine, they are not the easiest to screw in cause the 1.5mm hex is a bit shallow. It's no great issue, but is stands out as it's just not as great as the rest of the components.
Old 01-09-2015, 03:04 PM   #717
sgp-chris's Avatar
That's why I wan't to change them out. It might not be a big deal, but if it's possible to use another screw, I will do it for sure.
Old 01-09-2015, 04:00 PM   #718
An incredible stupid question:
How do you Mount your fans?
MiniZ racer trying out m-chassis and TC:)
lmlindbo is offline   Reply With Quote
Old 01-09-2015, 04:01 PM   #719
For four screws that you do once every blue moon if you are lucky (and if you run multiple diffs) - don't bother.
You could try to find a 2mm ish machine screw instead of a self tapper, but you would need to get a very small tap suitable for plastic also. Not so easy.
The xray t4-15 screws are 2.5mm (but 6mm deep not 8mm) and pretty sure the BD7 screws are about right - you could try and get them to fit perhaps if you really wanted to.
It all honestly, it's an "annoyance" not a "problem"
Maybe Naoto will loose his shit the first time he has to build one and they'll fix it
Old 01-09-2015, 04:03 PM   #720
With a fan/motor mount.
Or just with double sided tape. My WTF fan was held on for months with a piece smaller than my finger nail!
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
theproffesor
