Like Tree254Likes
Tamiya TRF419
Old 01-06-2015, 01:21 AM
  #676
lmlindbo's Avatar
Thanks.
But I cannot seem to load the pdfs. Anyone else having issues, or is it at my end as usual? :-)
Originally Posted by EDWARD2003
RedBullFixx is the man when it comes to setup knowledge and resources.
If you would like, I can do some videos on how to set ride height and various methods of measuring droop. Also, give you a few setup tricks and so on.
Thanks!
I'm a sucker for information, so that would be brilliant!
I think I know how to do it, though. But you are probbably better than me :-)
lmlindbo is offline
Old 01-06-2015, 01:33 AM
  #677
Simmi's Avatar
Ok my question is now answer by my self
Muchmore X-Gear Springs, read this on Marcs Facebook site. He uses in front Pink and Silver in rear.
X-Gear
Simmi is offline
Old 01-06-2015, 03:40 AM
  #678
X-Gear
Pink = "2.6" = 260gf/mm, close to yokomo yellow (according to petitrc chart)
Silver = "2.5" = 250gf/mm, close to yokomo blue
cplus is offline
Old 01-06-2015, 06:34 AM
  #679
Originally Posted by cplus
Being self tappers into plastic you need to be quite careful too. Torquing them down incrementally and not in a circular sequence (up/down, left/right) will help too.
That is an interesting point. Wonder if tapping the screw holes before actually putting in the screw would help with some materials. I know having a vertical drill press or mill worth it. You would want the the tapping to be as square as possible.
Cafe con Leche is offline
Old 01-06-2015, 11:44 AM
  #680
Some knowledge of other TRF cars seems to be needed to recognize some of the parts. I own TRF 417 and TRF 419, but NOT 416 or 418. So, I see the setup sheet mentions two different "Front Upright" as either 416 or 418. So, the question is "what is the difference, which one comes in the 419 kit?"
Thanks. I'd share my experience for my first day racing the 419 only to say it felt very stable and was fun to drive.
ic-racer is offline
Old 01-06-2015, 12:01 PM
  #681
The 418 ones have different mounting postitions for the steering arms, they are the ones included in the TRF419 kit.
Qatmix is offline
Old 01-06-2015, 01:21 PM
  #682
niznai's Avatar
Waste of time again TRF topics-style. The hole being formed all the way it will guide the tapping screw along, but I wouldn't use any cutting tools on plastics, they remove too much material, they're for steel and metals in general. Plastic works by moving out of the way a bit and gripping to provide friction to hold screws in, not by being cut and tightening screws in.
Get some silicone oil in the hole before you use the screw to tap it all the way, back off the screw half a turn for each turn (or 1/2 in - 1/4 out).
Even better, use Xray diff screws - they're machine screws and you can pre-tap with a "normal" one (i.e. not countersunk which will take a larger standard hex which gives more purchase). Same procedure - oil, 1/2 in 1/4 out.
niznai is offline
Old 01-06-2015, 02:34 PM
  #683
Thanks for responding. Now I wonder if I can standardize my spare parts and use the same 418 (54568) uprights on all of these cars:
417
419
TB04ProII
ic-racer is offline
Old 01-06-2015, 02:36 PM
  #684
niznai's Avatar
Older (two hole) uprights have the holes exactly either side of the new (418) type.
niznai is offline
Old 01-07-2015, 05:13 AM
  #685
masterhit's Avatar
Trader Rating: 16 (100%+)
Just a FYI,
The Samix aluminum chassis weighs 101 grams (just the plate not including the provided battery stops) compared to the stock chassis at 71 grams.
Mike
masterhit is offline
Old 01-07-2015, 10:38 AM
  #686
SoCalMitch's Avatar
Originally Posted by SoCalMitch
Does any know about the rates of the new TRF springs?
Tamiya TRF Damper Large Diameter Spring Set #42278
Red (soft), Black (Med), Yellow (Hard)
I guess the new spring rates are still unknown.
I will try out the Black (Med) this Saturday at Tamiya.
SoCalMitch is offline
Old 01-07-2015, 11:02 AM
  #687
Trader Rating: 77 (100%+)
Sorry i cant help but i will say that many of us were running HPI Silver's at Tamiya and liked them albeit on the 418. I know that doesn't answer your question. Good luck with the black ones. Let us know.
goin2drt is offline
Old 01-08-2015, 07:15 PM
  #688
Trader Rating: 18 (100%+)
Default New TRF driver
http://www.tamiya.com/japan/cms/tami...f20150109.html
back9monsta is offline
Old 01-08-2015, 07:53 PM
  #689
That is awesome.
goin2drt is offline
Old 01-08-2015, 07:56 PM
  #690
Took the 419 out tonight for the first time. First impression is awesome. No leaking diff or dampers. Had to make a few adjustments. I am not a pro but the car for me felt stable. The front end of the car felt better than my 418. I fealt the car steered more precise and went where i wanted it to go more so than my 418.
I like it.
goin2drt is offline
