Like Tree18Likes
Old 01-05-2015, 03:55 PM   #661
Sort of stock setup. If there really is such a thing :-)
At least stock Springs. Feels to soft up front.
On carpet with sorex 28. Dont remember what the body is called. Thought I'd try the front Springs from the evo6, as I believe they are a bit stiffer.
MiniZ racer trying out m-chassis and TC:)
lmlindbo is offline   Reply With Quote
Old 01-05-2015, 04:09 PM   #662
Marcika's Avatar
Hey guys,
I have tested 419. (missed 418, but have v5). I found the car well performing with stock springs, 450 oil on carpet (medium grip) better than with Yokomo springs (pink/blue). Wheelbase was adjusted, since it was too long for me. front 1mm, rear 1.5mm spacers for the blocks helped a lot. I had a lot of steering, but car&myself was not so fast.
Next race I will lower RC and using B-B block in front and narrower rear for sure. wheel: LRP CPX.
I am not a top-driver... just sharing experience.
Marcika is offline   Reply With Quote
Old 01-05-2015, 04:51 PM   #663
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Stock setup is precisely per kit build, always a good place to start
Stiffer springs may make the car even more agressive
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-05-2015, 05:13 PM   #664
Yes, I know.
But my manual says nothing about rideheight. And meassuring downstop at the setscrew is highly inaccurate. So my setup is stock as far as camber, cambergain, wb, ackerman, track, toe, damper-angle, caster etc goes. Droop, downstop and rideheight was my tuningtools today. Couldnt get it quite right, so next up is different Springs.
But please get the tips and tricks coming. I really have to learn this.
Im pretty sure that your input and my trial and error will make it brilliant in the end :-)
Old 01-05-2015, 05:40 PM   #665
Yes, I know.
http://www.petitrc.com/reglages/tami...iyaTRF419.html
Old 01-05-2015, 05:56 PM   #666
Questions??
Yes, I know.
Gordie
Gordie88 is offline   Reply With Quote
Old 01-05-2015, 06:00 PM   #667
EDWARD2003's Avatar
Yes, I know.
RedBullFixx is the man when it comes to setup knowledge and resources.
If you would like, I can do some videos on how to set ride height and various methods of measuring droop. Also, give you a few setup tricks and so on.
EDWARD2003 is offline   Reply With Quote
Old 01-05-2015, 06:10 PM   #668
Someone needs to get the measurements going for rc crew chief!
I assume the inner camber link locations are also a little more outboard than the 418?
Has the location of the steering posts altered with respect to the arms? Should photograph the two chassis side by side and compare.
cplus is offline   Reply With Quote
Old 01-05-2015, 06:16 PM   #669
EDWARD2003's Avatar
+1 on RC CREW CHIEF! This computer program is getting better and better each year!
Old 01-05-2015, 06:44 PM   #670
Trader Rating: 77 (100%+)
Got mine finished. Coming from the 418 and looking forward to taking it out on Thursday. I set this car up the exact same way as my 418 to start at that point. Had to make the rear holes a little bigger because the bodies were already cut for the 418.
Here are a few pics.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 01-05-2015, 07:18 PM   #671
lbckevin's Avatar
Trader Rating: 91 (99%+)
Looks great Todd.
You changed the stock springs out ? Did you try the stock x gear springs yet ?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-05-2015, 07:32 PM   #672
Originally Posted by lbckevin View Post
Looks great Todd.
Thanks. I have not. I was running the Yokomo pink and blue in the 418 so i stayed with that as a base. I may give them a go Thursday.
Old 01-05-2015, 10:43 PM   #673
Found these pics from some blokes build thread elsewhere.
Old 01-05-2015, 10:47 PM   #674
Dusttt's Avatar
Trader Rating: 123 (100%+)
Finally got a chance to get mine done just need to get it on the set up board and build the front diff.
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 01-06-2015, 01:41 AM   #675
Simmi's Avatar
What kind of springs is MR use?
I already saw the springs on a 419 during the publication?
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
