Like Tree7Likes
Old 12-29-2014, 11:18 PM   #601
Originally Posted by Simmi View Post
New Alu Chassis TRF 419 from Samix
More on RedRC
http://www.redrc.net/2014/12/samix-4...is/#more-90792
I wonder if this is what MR et all used at the ETS round a few weeks back....?
cplus is offline   Reply With Quote
Old 12-30-2014, 03:56 AM   #602
Skiddins's Avatar
It certainly wasn't the same as that.
Besides, it was a prototype, he showed me the underside and admitted the machining wasn't perfect etc.
He didn't mention if it was a Tamiya part or not.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-30-2014, 04:09 AM   #603
Cool. Thanks for the insight.
Old 12-30-2014, 09:11 AM   #604
Skiddins's Avatar
Sorry, admitted the machining was not perfect'
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-30-2014, 08:16 PM   #605
Originally Posted by kentech View Post
I measured it when I built the car but didin't write it down. I believe the difference was 1 or 1.5mm.
Just confirmed the 419 body hole is about shorter by 1 or 1.5mm
TamiyaW1688 is offline   Reply With Quote
Old 12-31-2014, 01:11 AM   #606
Marcika's Avatar
Hey guys,
Any idea how to fix balance of left-front?
Car is overall 1350g, rear is ok +/- 10g.
FL:294
FR:330
RL:323
RR:312
front left has bigger gap vs right (30-35g), despite I put some weight under servo 10g, under front spool 10g, under left side of bumper 10g.
moving lipo also didnt help much.
Thanks and happy new year.
Marton
Marcika is offline   Reply With Quote
Old 12-31-2014, 06:20 AM   #607
try checking your shock preload, that also influences weight distribution, and tweak (if there's any) as well.
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 12-31-2014, 08:57 AM   #608
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Marcika View Post
Hey guys,
FL:294
FR:330
RL:323
RR:312
Marton
Attachment 1259108
You should check chassis balance before chassis tweak
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-31-2014, 12:24 PM   #609
Marcika's Avatar
Check you mean without dampers attached?
Old 12-31-2014, 02:14 PM   #610
Everything you have bolted, stuck, strapped to your sweet new 419 chassis affects the L/R static balance of the car
Check on Balance pins, or the like first, before you start to check for dynamic balance
Also make sure your shocks are all the same length, and front wheels are pointed straight when using scales
Old 12-31-2014, 02:33 PM   #611
CraigMBA's Avatar
Trader Rating: 22 (100%+)
To add to what RBF wrote, If the car is ready to run, I'd move the battery closer to the centerline, or get a lighter battery. The car is "only" 16 grams heavy on the right side.
I just saw your picture. Strip all the weight off the car. There is something else wrong with your car.
Assuming the ride height is correct AND the car was untweeked, I'd add 1/4 turn to the LR and remove 1/4 turn from the RR. That will reduce the chassis cross weight a tremendous ammount.
Is the car brand new, or have you hit something with it?
Have at it!
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-31-2014, 09:45 PM   #612
Default can 418 upgrade to 419
hi all,i have a 418 can i upgrade to 419 and what parts i need to buy...happy new year
tinalau is offline   Reply With Quote
Old 12-31-2014, 09:51 PM   #613
Not going to happen. If you want a 419. Buy a 419. Suspension is the same. That's it
Juan Aveytia is online now   Reply With Quote
Old 01-01-2015, 12:20 AM   #614
Marcika's Avatar
Thanks for the feedback. Car is brand new, plan to run this weekend.i will double check screws,followed instruction during assemble. Dampers are ok, no difference inlenght. for sure i need extra weight to hit 1350g.
Have at it!
Old 01-01-2015, 12:31 AM   #615
Marcika's Avatar
What i have also realized the ride height is different ;( left vs right in the front with same damper setting (ring setting same 2.5mm for preload) so spring pre load should be the same if spiring is also same size (pink yokomo btw)...shall i change it to have same ride high? Thankswith
Have at it!
