Like Tree2Likes
Old 12-27-2014, 09:06 AM   #586
niznai's Avatar
Originally Posted by cplus View Post
Hey definitely do on the lower end kits.
Hell, you could build a TA06 tourer or CR-01 crawler with pretty much 100% hop up parts.
The 418/419 come pretty much fully loaded though. Compared to xray/yoko that are missing say floating servo mounts, DCJs or carbon parts the tamiya kits are not bad.
The ball nuts are a nice addition though, but $30 to get setup (incl. the hollow screws) is a little much!
Consumer level kits are cheap and that's what they should be.
TRF kits are not.
Not sure where you buy your grubscrews but I have a good nut and bolt shop just around the corner where I can get any length from 3mm to 25mm in 2mm increments and they're peanuts.
Tamiya's ball nuts are a different story. Nearly 10 bucks a set of 4 (plus postage)? And by the time you take out all the slop on all joints (steering and suspension) by using these, you're out of pocket way above any other kit on the market. This is not okay when the competition has slop free ball joints in their kits as standard (which is the way it should be). What's so difficult, anyway? Slop free joints are not an optional extra on a top spec car.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-27-2014, 10:27 AM   #587
Originally Posted by Marcika View Post
Hey,
Two more questions :
1. Do you know what to use for little plastic in K parts called as spare parts?
2. Which holes do you use in front outdrive? There are two positions....short makes so much play left-right...
Marton
darn now i have to check my car.... i didn't even use the instructions for drivetrain lol
i see hole put pin in..
Gordie
Gordie88 is offline   Reply With Quote
Old 12-27-2014, 11:29 AM   #588
Marcika's Avatar
Thanks for the clarification
Originally Posted by kentech View Post
On the front joints, it's shown in the manual which holes to use. They even added a "note direction" text there. You should use the holes that are not in-line with the driveshaft slots. Check the manual again and you will see.
Marcika is offline   Reply With Quote
Old 12-27-2014, 01:53 PM   #589
I was referring to the TRF hollow screws which are drug money
You're using them everywhere? Hell. Stuff that. I didn't think slop was that much of an issue, I only use the TRF ball nuts for convenience of shock removal. It didn't even occur to me to use them on all the joints.
cplus is offline   Reply With Quote
Old 12-27-2014, 02:19 PM   #590
Risky. Especially when the pin sizes are all so close.
Old 12-27-2014, 02:30 PM   #591
niznai's Avatar
Hollow screws? What do you need that for?
You're using hollow screws but think slop is okay? Do you race your cars or put them in glass boxes on shelves and list all the hop ups in your signature?
Team Greasy Weasel
Old 12-27-2014, 04:24 PM   #592
You're using hollow screws but think slop is okay? Do you race your cars or put them in glass boxes on shelves and list in your signature all the hop ups?
I bought them last time for the 418 before knowing better. Can't recall which of the build blogs (McPhee/kentech/rcracer) I copied it from. I'm not specifically advocating their use, that's for sure. But if you've got the coin and don't mind spending it - good luck
I don't think slop is "ok" I'm saying I didn't notice it as an issue on my car - but I haven't got much to compare to.
Old 12-27-2014, 04:26 PM   #593
Just to reach weight. The car was 1280g without weights, so I added 75g since the limit is 1350g.
Nothing special about my setup. You can read all equipment I use on my blog. Should be easy to reach this unless you use a very heavy battery. Remember you can play with the position of the receiver, transponder and ESC as well. Added most (50g) of the weight in the center of the car behind the servo mount and in front of the motor mount at about center line. The rest (25g) in front of the steering posts.
Thank you fort the response.
Would you recomend adding 40g extra (which would make my car 1380g) to have a perfect L/R balance, or is it better to save 40g and have a very slightly unbalance L/R ?
Thanks.
MatJ is offline   Reply With Quote
Old 12-27-2014, 09:07 PM   #594
Thanks.
You can offset the location of your lipo with. More/less spacers on the lipo stopper - have you considered that?
Old 12-28-2014, 12:38 AM   #595
Rear posts are a bit further back on the 419.
Can you define "a bit"? is it 1mm or less?
I slipped my old 417/418 holed body onto the 419 just fine without any modifications or adjustments when building according to kit.
torg is offline   Reply With Quote
Old 12-28-2014, 01:16 AM   #596
Simmi's Avatar
Yes, the Body from the 418, EVO 6 all fit the TRF419
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 12-28-2014, 03:58 AM   #597
I have, which does give better results for the front end (about 10g difference on each side) but the rear still causes some issues. There's a bigger gap at 10-25 g.
Old 12-28-2014, 07:02 AM   #598
Trader Rating: 77 (100%+)
Technically yes they fit. They are not exact. The rear posts are about a mm or two wider and farther back about the same. It is not an exact fit but you would need to only make your current rear holes a bit larger to get them to work.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-29-2014, 03:44 AM   #599
kentech's Avatar
Thanks.
I would try to make it as close to perfect at just about weight limit. Don't want to carry any extra weight around. As I say, it should be possible to get a very good balance at 1350 which is the normal limit.
I measured it when I built the car but didin't write it down. I believe the difference was 1 or 1.5mm.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-29-2014, 10:50 PM   #600
Simmi's Avatar
New Alu Chassis TRF 419 from Samix
More on RedRC
http://www.redrc.net/2014/12/samix-4...is/#more-90792
Team Yokomo YZ2 CA
