Old 12-24-2014, 04:38 AM   #556
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Steering should be exactly the same as the 418 I believe. I used a .15 shim instead of the stock .1. I tried doubling on on the .1 shims to make .2 but it starts binding up if you torque down the screw.
With the .15 shim, it is just right. Hardly any up/down movement, but the bellcranks move freely. The shim set I bought is a 3racing set from TQRC. I'll need to dig up the part number for the set.
Dan is offline   Reply With Quote
Old 12-24-2014, 06:16 AM   #557
Marcika's Avatar
thanks. I dont have 0.15 but I will have :-)
Marcika is offline   Reply With Quote
Old 12-24-2014, 05:18 PM   #558
Dan
Dan's Avatar
http://www.tqrcracing.com/shop/produ....asp?p_id=7244
Here is the shim set I bought.
Old 12-24-2014, 05:39 PM   #559
R3DB16's Avatar
Trader Rating: 91 (100%+)
Originally Posted by cplus View Post
Damn. It's turned up before the Hiro Seiko screw kit and a few other bits and pieces for the build!!
MUST. NOT. BUILD.
I'm in the same boat, still waiting for a couple more things. Christmas came early but I must resist...
TB03 | TA05-V2 Gold | XV-01 Pro
Tamiya | Sanwa | Orion | TQ R/C
R3DB16 is offline   Reply With Quote
Old 12-25-2014, 03:02 AM   #560
Simmi's Avatar
With what Kind of camber do you race on carpet?
Positive or Negative camber?
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 12-25-2014, 05:25 AM   #561
Always negative. In the region of -1.5, then tweak to your liking.
MatJ is offline   Reply With Quote
Old 12-25-2014, 06:05 AM   #562
Simmi's Avatar
Thank you, because I hardly think Marc and Viktor in their setup sheet specifying the correct camber.
Team Yokomo YZ2 CA
Old 12-25-2014, 06:27 AM   #563
niznai's Avatar
Really?!
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-25-2014, 11:15 PM   #564
I think they just consider that there is no other option but negative, so no point wasting ink on a minus sign.
Try and drive with 2deg +VE and just watch what happens to front end grip (and tyre wear pattern)
cplus is offline   Reply With Quote
Old 12-26-2014, 06:30 AM   #565
kentech's Avatar
Originally Posted by Dark77Hawk View Post
To kentech and others who have fully built they cars, how much does she weigh,I know it will be different from person to person, i just want to get a rough ballpark figure thank you.
Finally added servo, motor, ESC, receiver etc.
With indoor insert tyres and a 95g body my car was 1280g.
See more details here: http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-26-2014, 07:21 AM   #566
Trader Rating: 77 (100%+)
Sure looks purdy.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-26-2014, 07:23 AM   #567
Thank you kentech I run 13.5t and my tb04 pro 2 comes in at 1493g think time for a new car
Dark77Hawk is offline   Reply With Quote
Old 12-26-2014, 10:27 AM   #568
@kentech
Where or how do you do the carbon weights as well as your CF on the transponder? I have done some basic CF sticker sheet from eBay but never looks like that.
Old 12-26-2014, 11:04 AM   #569
Jochim_18's Avatar
Originally Posted by grippgoat View Post
Brownouts, failing receivers, models getting wiped if you turn off the power at the wrong time, etc. Seen a few locals spend $$ on the high-end Ko stuff and then get frustrated with random issues, then replace it with Futaba or Sanwa, and be happy.
-Mike
Oh yah the dreaded gremlin on my Ko propo EX-1
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-26-2014, 11:07 AM   #570
Jochim_18's Avatar
Originally Posted by subaru73 View Post
I have ran ko for years and no problems but I use the euros radio
Ko propo Helios or Eurus has no issues.. But when I switch to Ko Propo EX-1 OMG I got issues one after another and finally gave up and switch to Airtronics M12 and couldn't be any happier. However my 9 year old Ko propo helios still rockin and my 6 years old son is using it now.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
psarver22
SEO by vBSEO 3.5.0
