Like Tree1Likes
Old 12-20-2014, 07:22 AM   #526
kentech's Avatar
Originally Posted by goin2drt View Post
Anyone coming from 418 to 419 and can tell me if the body posts positions are the same? Curious if my 418 bodies will fit on the new car without new holes?
Rear posts are a bit further back on the 419.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-20-2014, 07:24 AM   #527
Trader Rating: 77 (100%+)
Thanks and that sucks i have two freshly painted bodies i wanted to use but already cut for my 418.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-20-2014, 07:38 AM   #528
niznai's Avatar
There's plenty of workarounds for that problem and it's not rocket surgery.
The rear body posts on TA05 cars are offset a different amount so you can flip them around to give slightly different positions. The hole/stud are a perfect match for the Tamiya cars (I use them on my 418, but they match the older TA05MS, etc.).
Then there's plenty of other cars like Kawada, Xray, Yokomo which again have posts that can be used to achieve a different positioning of the point where the post goes through the body. All of these match the hole/locating pin/stud positions as if all manufacturers agreed on it so they go straight in the holes in the shock bridge across all cars.
I'll leave it up to you to do the required research to find the part numbers.
If you can't be buggered to do any of that, you can just use longer screws and some washers/spacers to offset the 419 posts the desired amount. If you need too big an offset and the stud does not reach the locating hole, you can just drill it and use a second screw instead of the stud.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-20-2014, 07:48 AM   #529
Originally Posted by niznai View Post
If you can't be buggered to do any of that, you can just use longer screws and some washers/spacers to offset the 419 posts the desired amount..
I like that as a short term fix. With my driving it wont be long before i get a new one
Old 12-20-2014, 02:01 PM   #530
You can just over ream the body and then tape/goo a piece of polycarbonate square with the correct size hole in place too. I didn't this to an older body and it lasted me ages.
cplus is offline   Reply With Quote
Old 12-20-2014, 09:33 PM   #531
niznai's Avatar
I have managed to build up a stash of body posts from all sorts of cars and now I can drill my bodies once and am sure they fit all the cars I have. The distance between posts at the back is spot on the same on all cars, at the front it's within 1-2mm so inside the tolerance of the holes I ream in the bodies.
Team Greasy Weasel
Old 12-20-2014, 10:11 PM   #532
hanzo3's Avatar
Trader Rating: 55 (100%+)
Finished the 419 Build blog post yesterday.
In case you have not got the 419 yet, I hope it will help show the details of the car.
http://kentech.blogs.se/
Great pics and writeup as always. You should be the stock photo guy for tamiya.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 12-22-2014, 02:22 AM   #533
Default how much does she weigh fully loaded
To kentech and others who have fully built they cars, how much does she weigh,I know it will be different from person to person, i just want to get a rough ballpark figure thank you.
Dark77Hawk is offline   Reply With Quote
Old 12-22-2014, 05:34 AM   #534
Trader Rating: 18 (100%+)
I think they should have stayed with the while spool/diff gears.
They looked nicer.
thejo3 is offline   Reply With Quote
Old 12-22-2014, 08:02 AM   #535
Trader Rating: 38 (100%+)
Default first run. 419
I was very pleased with first time out. Carpet, 17.5, yokomo pink front, blue rear. 45 associated shock oil. new diff is so smooth and I welcome the "black"
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 12-22-2014, 12:32 PM   #536
RC MARKET's Avatar
New Spare & Option Parts
Tamiya TRF419-ta-51565.jpg   Tamiya TRF419-ta-51567.jpg   Tamiya TRF419-ta-54621.jpg   Tamiya TRF419-ta-84402.jpg
RC MARKET is offline   Reply With Quote
Old 12-22-2014, 12:51 PM   #537
Default radio help please
Hi guys. Please need your input as I want to invest in long term radio.
I am currently using Spektrum 4R.
Benefit to go to M12, Ko Propo V3, Futaba 4px?
Signal strenght, response time etc?
thanks
Old 12-22-2014, 12:58 PM   #538
lbckevin's Avatar
Trader Rating: 85 (99%+)
What brand spur gears are fitting on the 419. Trying to help out a buddy.
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
Old 12-22-2014, 01:15 PM   #539
thanks
Our local club forum has had the same questions.
long story short:
Futaba, sanwa, KO all high end based radios with high quality internals. They will all be faster in response time and feel better. More accurate which we proved multiple times at my club.
With this is I have a Carbon wrapped Futaba 4PX I am willing to let go.
let me know.
Gordie
Gordie88 is offline   Reply With Quote
Old 12-22-2014, 01:29 PM   #540
Same as 418
Kawada super Ex, panaracer/xenon, leespeed.
