Like Tree7Likes
Old 12-13-2014, 12:13 AM   #496
Simmi's Avatar
Originally Posted by cplus View Post
Simmi, couple of queries
Why the roche cups - aren't the new ones blade free? Didn't want to try them?
Shorter turnbuckles are an oddity. I was thinking of grabbing a BD7 (Lunsford) kit to use, the equivalent are all slightly shorter than typical Tamiya as well.
What screws have you used - your button heads all have a little lip?
I think I try the Arrowmax BD7 Aluminium Chassis for Carpet
Tonisport 25
I use the Roche Cups and Roche HD Double Joint since I drive the TRF V5. The Tamiya Cups and Double Joint where not very stable, as an experience I made.
Little Lip? The screwas are from square Alu Titan and some Arrowmax Titan Screws the darker ones.
@goin2drt
No
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 12-15-2014, 12:29 AM   #497
kentech's Avatar
Finished the 419 Build blog post yesterday.
In case you have not got the 419 yet, I hope it will help show the details of the car.
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-15-2014, 02:38 AM   #498
Default First Race with 419
Did the first racing with the 419 last weekend on a very small and technical Track, carpet with medium Grip. 17.5 Blinky, LRP VTec CPX rubber tyres.
Started with Kit Setting what was nice and very easy to handle with good steering, but not aggressive enough. Then changed setup to:
Yokomo pink in front
Yokomo blue in rear
Droop f/r 5.8 / 4.6
Without lower Rollcenterspacer
Camber f/r -2 / -1.5
Shocks: #500 oil front & rear
Car was still very easy to drive with very good steering especially in narrow corners, but again not aggressive/ direct enough. Reduced droop in front to 6.0 what was leading into right direction, but there is still work Do for a sharp handling. Will try some harder springs and stabilizers next time.
BUT: my Diff was leaking too, first the housing (gasket) and then the left outdrive. Drops were already running down, there. Right side of diff stayed dry. Used the dark red TRF o-rings. Also all shocks are massively leaking, used the ink blue TRF o-rings. Very disappointing....will change to the old cristal clear ones because refilling dampers during a race day is a nogo to me.
But the 419 is a fantastic car, I am glad to own one😄😄😄😄
Evo4ever is offline   Reply With Quote
Old 12-15-2014, 07:18 PM   #499
Just got my 419 from Hong Kong.
ic-racer is offline   Reply With Quote
Old 12-15-2014, 07:19 PM   #500
Starting the build...
Old 12-15-2014, 07:21 PM   #501
One thing in the manual I almost missed. The spur gear in the kit is pretty thin in the middle. To use thicker spur gears you won't be able to get the E-clip on, but you can leave the E-clip off the spur gear axle and use some spacers instead.
Old 12-15-2014, 08:20 PM   #502
syndr0me's Avatar
Trader Rating: 32 (100%+)
The new gear diff leaks too?!
syndr0me is offline   Reply With Quote
Old 12-15-2014, 11:32 PM   #503
niznai's Avatar
Yokomo blue in rear
Droop f/r 5.8 / 4.6
If nothing is seriously wrong with the parts, there should be no leaks, kit parts or upgrades. I would check my handiwork again if that is the case. Never thad any Tamiya shocks leak, ever.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-16-2014, 12:39 AM   #504
Agreed. I do run either VG shock grease or green slime as well though. I've never had a diff leak either (but also run 2000-5000 diff oil which probably helps.
cplus is offline   Reply With Quote
Old 12-16-2014, 06:50 AM   #505
My Diffs leaked too... But i may have over filled it...
I had slight shock sweating... but thats normal for me...
Gordie
Gordie88 is offline   Reply With Quote
Old 12-16-2014, 06:02 PM   #506
Dusttt's Avatar
Trader Rating: 119 (100%+)
Originally Posted by RC MARKET View Post
this week arrive $455 only !
Ordered mine on the 8th and got it here in SoCal today! Great service as usual!
"Whiskey Tango Foxtrot"
Dusttt is online now   Reply With Quote
Old 12-18-2014, 01:07 AM   #507
TB03Racer09's Avatar
How wide are the battery tape slots in the trf419 chassis? Have to make sure before buying a big roll. Thanks
TB03Racer09 is offline   Reply With Quote
Old 12-18-2014, 03:06 AM   #508
can't see them being different to he 418 - which is 20mm+
17/18mm xenon/hudy/tamiya/etc (all of them are Slion pretty sure) tape
Old 12-18-2014, 05:57 AM   #509
Bar
Hudy is different, a lot better quality, sticks so much better
Luke Burr
Bar is offline   Reply With Quote
Old 12-18-2014, 11:52 AM   #510
Smile
Can't beat Hudy tape its expensive but sooooo good
RandR is offline   Reply With Quote
